Old 30th January 2007, 03:10 PM   (permalink)
Default timer switch not working
hi guys,
got a problem with some timer switches(220VAC,24VDC).
the problem is that they seem to work at times but sometimes not.
They are on-delay timers , so after some pre-selected time the normally closed switch should open and the normally open should close and all this happen when the timer is supplied with voltage,and to re-initialise them the voltage should be removed.what actully happen is that when its time for the switch to close or open it just oscillate from closed to open position twice or sometimes thrice and then regain its normal behavior.
There is a 16-stage binary counter(MC14541BCP) and a transistor(C5468, by the way someone have its datasheet? ive searched but not found.) which i think might be causing this.the timer works also with dc supplies(24V),and it works perfectly.Someone have an idea what might be causing this?
vinke is offline   Reply With Quote
Old 31st January 2007, 02:23 AM   (permalink)
The transistor is probably a 2SC5468 so search for that.
It is likely that the 220Vac to 24VDC power supply part of the circuit is defective?
kchriste is offline   Reply With Quote
Old 31st January 2007, 02:35 AM   (permalink)
Default Transistor data sheet.
Hi Vinke,
The datasheet of the 2SC5468 can be found here:
http://www.alldatasheet.com/view.jsp?Searchword=2SC5468
on1aag.
on1aag is online now   Reply With Quote
Old 31st January 2007, 02:24 PM   (permalink)
thks,
ive re-soldered every point on the board and its working now,surely a dry point was causing this.
A/B Video Switch with 5-Second Timer JackOlsen Electronic Projects Design/Ideas/Reviews 2 6th January 2007 01:31 AM
PIC Switch Management Techniques Mike, K8LH Micro Controllers 2 28th September 2006 12:33 PM
switch state based on timer Patchouli Micro Controllers 2 18th January 2004 08:51 PM
555 Timer Not Working Correct Kane2oo2 Electronic Projects Design/Ideas/Reviews 1 13th October 2003 08:27 PM
Using a switch to bypass 555 timer? sjaguar13 Electronic Projects Design/Ideas/Reviews 5 3rd July 2003 02:50 PM
