| after an hour searching google for a schematic for a 12 volt to 24 volt Dc to Dc converter. I need a schematic for a Dc to Dc converter that will turn 12 volts DC into 24 volts DC on the output, the output needs to be atleast 4amps. I will be operating a DC motor on the output. Any help would be appreciated Thanks | |
| I went though this a while back. For a beginner (like me) its complicated. There is alot of info here: http://www.smps.us/ I had another site with a good schematic but I don't have it bookmarked here at work. I'll post it tonight if I remember. | |
| This isn't a good application - assuming the motor takes 4A when running, it will probably take more than 40A at startup or when stalled. But in any case, an inverter probably isn't the best solution? - changing the motor to a 12V one, or the supply to a 24V one makes more sense! - and is probably more cost efficient as well?. As usual, give more details!. | |
| Buying a motor of the right voltage will probably also work out cheaper than an inverter anyway.
| If you're stuck with the motor you may be able to rewind the motor coil for 12 volts.
| 6 volt dc circuit to 12 volt lights | jace33 | Electronic Projects Design/Ideas/Reviews | 5 | 20th October 2006 11:39 PM |
| USB - TTL Converter | samltd | Electronic Projects Design/Ideas/Reviews | 5 | 7th July 2006 10:46 PM |
| 6V to 12 volt converter ckt dicrete or IC based | nikhil arora | Electronic Projects Design/Ideas/Reviews | 5 | 1st April 2006 05:51 AM |
| Dc-Dc converter 0.8v->12 volt | schrodingerscat | Electronic Projects Design/Ideas/Reviews | 10 | 19th December 2005 12:19 AM |
| How to build a converter from 12 Volt to more than 200 Volt | Christopher Ooi | Electronic Projects Design/Ideas/Reviews | 10 | 27th May 2003 02:34 PM |
