I didn't concentrate on the circuit to really try and understand it, however I can see that the differences between the two transistors will mess it up, you need a matched pair of transistors.
below is the circuit i've been using. one of the 1.8v LED's is mounted inside a small tube, opposite a LDR which affects a midi controller value. the optoisolator outputs are fed into a cmos circuit that eliminates bounce/false triggering and eventually triggers a midi note-on/off. so for each pair of electrodes, closing the circuit with light touch turns a midi note on, and then further contact (more surface area, less resistance) generates midi controller data. [EDIT: the extra 1.8v LED and 2.2v LED are just indicators.. 1.8v matches whats happening with midi data, and 2.2v is normally on, turning off when a note is triggered] the reason electrodes are on the floor is that contact dancers are to interact with them, essentially forming human chains between various electrode pairs to generate music, playing on amount of skin contact. but for the purpose of my query as to how to use just one power supply instead of a battery per pair of electrodes without losing the current independance, one only has to consider a single human body making contact with more than one pair of electrodes. Last edited by sstimuluss; 29th January 2007 at 07:07 PM. |
bump.. please help, i've been looking for a solution to this problem for weeks now. Granted I can just use a battery per touch circuit, but there Must be a more elegant solution!
Ideally I would like to be able to power multiple touch circuits from a single AC-DC transformer with a regulator to smooth out ripple etc. If my actual problem isn't explained well enough, please let me know and I'll try to clarify. |
I finally understand your problem. The only solution I have thought of so far is much more complicated, involving either frequency or time selective circuits. How many pairs of electrodes do you have on the floor?
The key is, that the negative and positive of the battery cannot be common. A transformer with multiple secondaries and rectifiiers (one for each circuit) is all that you need (or multiple transformers). That would be a custom design.
see my website: www.geocities.com/russlk |
if a custom transformer design ends up being too much work for me (i have deadlines for show unfortunately), I'll have to use multiple transformers.. i recently picked up seven or so 8.5V 60mA AC-DC adapters at the dump, however when reading their voltages with a multimeter, an open circuit measures 14.2V, a 1M resistor measures 13V, and a 1.5K resistor measures 9V .. this isn't the same as another adapter i have which measures 9.15V no matter what.. doesnt seem right.. and a bit scared to use them in a circuit designed for 9v.. i'm guessing they're old cellphone chargers, which may use different transformer design to regular adapters |
I've pondered over that approach as well, but not yet tried going down that route.. to somehow step through the touch circuits one by one to take readings eh? that would eliminate the need for exclusive V+ and Gnd.. would it be possible to take this approach and not have the LED's flicker on and off? even the slightest ripple causes oscilation in the midi controller data, not good |
Each circuit has an oscillator (relatively low frequency) connected to one electrode, and a tuned amplifier connected to the other electrode, and a synchronous demodulator following that receiver, the output signal being proportional to the resistance between the electrodes. You would then use that output to drive your MIDI transducer. The frequency selectivity would cause it to reject signals from another electrode, which would be at another frequency. Time division multiplexing: Generate N pulse trains with duty cycle=1/N, where N is the number of transducer pairs, and each pulse train would be at a different phase (time slot). You could then synchronously demodulate the pulse trains (the demod acts as a sample-and-hold), and feed each output to its respsctive MIDI transducer. Russ's separate transformer windings and regulators might be easier. Your idea of isolated DC-DC converters should also work. It still boils down to separate transformers (inside the DC-DC converters). Last edited by Roff; 30th January 2007 at 11:46 PM. |
(permalink) | ||
The simplist solution is multiple transformers, this is the circuit. Parts are available from Mouser (www.mouser.com). The capacitor, C1, is probably not needed for your application. You could use the whole secondary but the output voltage would be double (about 18 volts).
12.6V CT, 150mA 2VA Centre Tap - Type 2851 Transformer http://www.jaycar.co.nz/productView....=&SUBCATID=411 also, would there be much fluctuation in the output voltage? |
Yes, that transformer would work fine.
| Voltage | ElectroMaster | Electronic Theory | 44 | 8th August 2007 05:35 PM |
| voltage and current source | Gaston | General Electronics Chat | 14 | 8th March 2005 05:45 AM |
| General Nodal Analysis with Voltage Sources? | petesmc | General Electronics Chat | 1 | 3rd February 2005 12:46 AM |
| MOSFET Search - Low Gate to Source Voltage | devonsc | Datasheet/Parts Requests | 6 | 5th December 2004 10:52 PM |
| Newbie- I want to pulse a low voltage high amp source. | ukmxer | General Electronics Chat | 5 | 30th September 2003 07:23 PM |
