| hi guys, im working on a board and i was wondering if there was a quick and simple way of testing transistors. thks. | |
| The first test, which is not 100% but is a good start: Assuming you are using a DMM with a "diode" range, 1 Put the test meter positive lead to the base of the transistor and then measure to the emitter and then to the collector. 2 Put the test meter negative lead to the base of the transistor and then measure to the emitter and then to the collector. With the leads one way you should measure about 0.7v, them the other way round you should measure an open circuit. This simple test will usually find open or short circuit junctions in bipolar transistors (not FETS or MOSFETS), but is easily confused by the rest of the circuit still connected to the transistor. Dont forget that the power to the circuit board must be turned off. JimB
| thks buddy.i would like to know if it also applies for darlingtons | |
| Yes, should be no problem with darlingtons either. What you should see with a darlington is a higher base-emitter voltage, about 1.2 to 1.4 volts. This is due to there being two junctions in series. JimB
__________________ --- The days of the digital watch are numbered. --- | ||
| I have never seen a collector-emitter short that was not shorted all the way around.
| While possibly obvious to the professionals, mis-identification of leads can cause some confusion. I friend and fellow hobbyist was going in circles trying to debug a simple circuit using common 2N2222 transistors. Turns out that the leads were different between manufacturers. We dropped them into the transistor checker on my DMM - which identifies the leads - transistors worked fine once wired correctly.
__________________ stevez | |
| A 2N2222 is an NPN transistor in a TO-18 metal can, the tab indicates the emitter. You won't find one different unless it is mismarked by error.
| It may be the result of memory lapse on exactly which transistor but it was a general purpose one - and we stumbled on the problem by putting the transistor in the tester. It identified the leads - indicating them as different than what he had been expecting (using a different mfr's datasheet). We pulled a datasheet for the device in hand - it matched the transistor. Once the leads were in the right place the circuit worked. I do not recall if one might have been metal can - the other plastic. Again, maybe be one of those things that's obvious to the professionals but it was not obvious to my pal - or me initially.
| Plastic transistors are a problem, there are 3 leads and 9 ways to bring them out, and all 9 have been used.
| | (permalink) | ||
__________________ --- The days of the digital watch are numbered. --- | |||
your DMM behavior also matter-- some don't rearad forward voltage of diodes or LEDs. how ever you can test them while the board is powered, you can measure the voltage across base and emitter-YOU GET AROUND .6 TO .7 VOLTS DC -OFCOURSE EXCEPT WHEN THE DEVICE IS WORKING AS AN OSCILLATOR. the voltage drop across emitter resistor is another indicator after base emitter drop- that the device is functioning- again not when collector emitter short as kchriste pointed out. if this short is there, you can get direct behavior of potential divider formed by collector resistor and emitter resistor (almost).
| With most 2N2222's in T0-92 package, if you hold the transistor between thumb and forefinger (right-handed) with the flat side against your finger, the emitter will usually be the bottom-most pin.
__________________ All those who believe in psycho kinesis, raise my hand. | |
| Good Electronic Supply's Sites, Everyone Come On In! :P | Electric Rain | General Electronics Chat | 44 | 28th August 2007 12:06 AM |
| faulty digital components testing,checking | walters | General Electronics Chat | 5 | 22nd August 2005 08:10 PM |
| Building a test set. | Freezerburn | Electronic Projects Design/Ideas/Reviews | 2 | 3rd May 2005 02:15 PM |
| ya | mari_69 | Micro Controllers | 4 | 7th June 2004 02:29 PM |
| Test For Inductor Motor :No-Load and Blocked Rotor Test | shermaine | General Electronics Chat | 7 | 28th March 2004 03:06 AM |
