Old 12th August 2003, 11:59 PM   #1
Default Convert Leds to 7 Segment Display
I would like to convert 6 leds to 7 segment display. What is the best way to do it? The way it works right now that LED’s lit up in a continuous style (for example: 1st will light up the 1st LED, 2nd will light up the 1st and 2nd LED, 3rd will light up the 1st 2nd and 3rd LED’s, etc. etc) I got 7 negative inputs and 1 positive signal as you can see from the picture that every led get grounded to lit up.
Almazick is offline
Old 13th August 2003, 06:46 AM   #2
How can you construct 7-segment display using 6 LEDs?
Please be more clear.
kinjalgp is offline
Old 13th August 2003, 07:37 AM   #3
I want to replace 6 Leds with 7 Segment display so it will display number from 1-6 instead of leds to lit up
Almazick is offline
Old 13th August 2003, 09:00 AM   #4
simple solution: use a 8 to 3 priority encoder and then a converter from 4 bits to 7 segment display. the priority encoder must be active low.
i'll look for some IC's for this.
bogdanfirst is offline
Old 13th August 2003, 01:36 PM   #5
CD4532 is a 8:3 priority encoder chip and 4511 is a BCD to 7-segment display driver.
kinjalgp is offline
Old 13th August 2003, 01:50 PM   #6
Or You can use diode array... and don't forget the serial resistors for segments.
Sebi is offline
Old 13th August 2003, 04:55 PM   #7
Default Woops !
Sebi
If input 3 is active (as I understand it) inputs 1 and 2 will also be active, so the display will show all 7 segments lit (displays '8' ).
Some priority encoding is required ?
Or is the diode matrix intended to still use the CD4532 8-to-3 encoder (and a decoder).
I need a memory upgrade ...
My head is full !
mechie is offline
Old 13th August 2003, 05:18 PM   #8
i think that the 8 to 3 and decoder is the only way.
the diodes would have worked better if you had only one led on for the specific number
Old 13th August 2003, 06:07 PM   #9
His design uses several comparators.
http://www.electro-tech-online.com/v...ic.php?p=13146
With a LM3914 he could get one active (LED) output.
Are you locked in to seperate comparators?
Mosfet is offline
Old 13th August 2003, 06:47 PM   #10
Mechie,
maybe with my bad english cannot understand right this sentence:
" I want to replace 6 Leds with 7 Segment display so it will display number from 1-6 instead of leds to lit up."
I think, only one input active (not two or more) and need to feed to 7segment display. In this case the diode-matrix can work.
Sebi is offline
Old 13th August 2003, 07:02 PM   #11
Default Re: Convert Leds to 7 Segment Display
so whatever number you have, that number of leds you have lit.
1: LED1
2: LED1 & LED2
3: LED1 & LED2 & LED3
Old 13th August 2003, 07:09 PM   #12
O.K.
......i thinking....
Sebi is offline
Old 13th August 2003, 10:54 PM   #13
Here is a possible solution, but this is only a small exercise for my brain...
Sebi is offline
Old 13th August 2003, 11:54 PM   #14
Hey Sebi! It actually looks like it might work. One more question. I get 6 negative inputs and 1 positive input to 7 segment display and as I can see from your picture that all 6 inputs are positive. Is it possible to put HEX Inverter to make it work? Thanks a lot
Almazick is offline
Old 14th August 2003, 12:49 AM   #15
couldnt you do this...?
e is offline
