Old 20th January 2007, 12:46 AM   (permalink)
Default hi guys im new here
hi guys my name is martin .. i come here for some assistance in a project i started and bit off more than i could chew im an auto electrician and decided to put auto fold unfold mirrors on my car... they already do so at the touch of the switch when you press 1st time it pulses to miror for 5 seconds then 2nd press the same etc etc i want to make it so when i set my alarm it folds mirrors and vice verser....
i have attatched a few images to show what i need but i really dont know where to start than i think i need a microcontroller??
if any one can help id qapreciate your knowledge very much so i can complete my project.... and get on with my life hehehehe thx alot in advance
can it be done?
this is whats inside the switch for mirrors and how it works...
and what i need to happen
thx again i hope some one can help me......
madmanc is offline
Old 20th January 2007, 01:38 AM   (permalink)
Well a microcontroller would let you do anyhting you want, but there might be a more hardware, "less software" method to do it if you really want to go that way, but it's probably more complicated *if* I kind of understand what you are trying to do, but I can't really figure out what's going on (maybe that's a sign?). If you use a microcontroller, you just wire in all the inputs and have it switch the outputs however you wish. It's probably easier to just do that.
dknguyen is offline
Old 20th January 2007, 08:36 AM   (permalink)
ok great thx theres 6 input wires all negative at rest and 8 outputwires negative at rest. any time the mirror switch is pressed 2 inputs will go positive. on the next press the opposite 2 will go positive. on a press of my key 1 wire will become positive and on the next press the opposite will become positive. only these 2 wires need the pulse to be extended. but both the key wires need 2 outputs each... .
its hard to explain...... is there a micro controller for n0obs that explains how it works etc.... and if i could get the boards conponents sorted then maybe id have a chance at completing it myself
thx for your replay i apreciate it.
madmanc is offline
Old 20th January 2007, 08:59 AM   (permalink)
Lightbulb
I'm not sure if I understand it properly, but here's my suggestion.
If you just need to extend the output pulse from the alarm system from 1 sec to 5 sec, you should be able to do this using a 555 timer circuit in monostable mode (just search on google for 555 monostable). You'll probably have to alter the resisitor and capacitor for the desired time (5 sec).
If you go this way, you would need 2 circuits, one for the lock > fold signal and one for the unlock > unfold signal. You can 'split' the output from each circuit into 2 (or have each circuit drive 2 transistors, to switch 2 different loads)
Also, if the pulse required by the mirror control unit is more than 200mA, you would need to use a transistor driven by the 555 to switch it (max output of ne555 is 200mA). I assume the pulse is actually driving the motor for the mirrors, so it will almost certainly be more than 200mA. It's probably safer and easier to use transistors to switch the load.
This will be a larger circuit than using a microcontroller circuit, but it doesn't involve any programming, or buyin a programmer.
Hope this helps
'Intellectuals solve problems. . . Geniuses prevent them.' . . . Albert Einstein
fingaz is offline
Old 20th January 2007, 01:14 PM   (permalink)
its a great start for me to be honest at least now i know what to research
thx very much....
madmanc is offline
Old 20th January 2007, 03:57 PM   (permalink)
This may do it if you can get output directly from the alarm unit. It would be as if you pressed the mirror fold switch. If you have to get your signal from the door lock wires, no matter how you do it you may find that the mirrors fold every time you operate the door locks or put the car in gear if it has the autolock feature.
Somehow I suspect that the body control module controls all of that so you won’t get output directly from the alarm unit.
C:\WHUT ?
Beware the asterisk *
ClydeCrashKop is offline
Old 20th January 2007, 04:56 PM   (permalink)
If you don't like the idea of building a circuit, you could always consider a PLC, but they can be expensive.
Screen name: Aloone_Jonez
Hero999 is offline
Old 21st January 2007, 01:18 AM   (permalink)
i tried with relays and diodes but the negative at rest disapears so the motor only recieves a positive feed at any one time....
madmanc is offline
Old 21st January 2007, 01:56 AM   (permalink)
thx for all your help i really apreciate your time i think ive done it now
barr extending the pulse from 1 to 5 seconds........what is the cheapest and easiest way to do this ? thats if i can have my cake and eat it.....
madmanc is offline
Sorry Guys Roboticinfo Chit-Chat 83 25th November 2005 01:45 AM
plzzz.. guys help me out neocharge Electronic Projects Design/Ideas/Reviews 3 16th January 2005 08:32 PM
automatic curtain project need help from u guys! tody0512 Feedback/Comments 2 4th October 2004 08:56 AM
Hello,Can any of u guys help me with good project sites ? mailboy Electronic Projects Design/Ideas/Reviews 2 6th January 2004 08:03 AM
Pleas guys the specifications of the amplfier JRC4558 timothy Datasheet/Parts Requests 3 2nd September 2003 06:11 PM
