Old 19th January 2007, 01:07 AM   (permalink)
Talking Man connects himself to TV Flyback transformer to generate arcs from his fingertips!?
http://www.youtube.com/watch?v=9MJ0F9x92fE
Kids, don't do this at home!
"Everything that is done in the world is done by hope." -Martin Luther
"There are two ways to live your life. One is as though nothing is a miracle. The other is as though everything is a miracle."-Albert Einstein
Analog is offline
Old 19th January 2007, 01:24 AM   (permalink)
Wow. Not exactly to bright, is he?
Andy1845c is offline
Old 19th January 2007, 02:02 AM   (permalink)
Genious! I agree, don't try this at home...
There is no "I" in "team", unless Apple makes it... Then it would be iTeam.
Marks256 is offline
Old 19th January 2007, 02:05 AM   (permalink)
He's probably got a metal wire or something concealed under his finger. At one point, he seemed to jerk as if he got zapped for real.
i_build_stuff is offline
Old 19th January 2007, 02:07 AM   (permalink)
wouldn't the same amount of heat on one end of the arc be the same on the other? another words wouldn'r it burn his finger
Gaston is offline
Old 19th January 2007, 02:08 AM   (permalink)
actually, he is kinda bright, in a 'jacobs ladder' type of way
Analog is offline
Old 19th January 2007, 03:21 AM   (permalink)
what is the frequncy of a flyback?
Gaston is offline
Old 19th January 2007, 03:43 AM   (permalink)
I think it is like 50 or 60 hertz... don't quote me on that, though... Aren't some around 70-80?
Marks256 is offline
Old 19th January 2007, 03:49 AM   (permalink)
Wikipedia says more like 15khz. I'm not sure though. I'm sure someone here knows...... Nigel?
Old 19th January 2007, 06:02 AM   (permalink)
The frequency of a TV flyback is 15,750hz PC monitors have a significantly higher frequency because the lines/refresh rate are higher.
straight answer, har har."
Sceadwian is offline
Old 19th January 2007, 06:05 AM   (permalink)
I don't see how a person could conduct that much electricity from one hand to another without harm, not across the chest cavity. There has to be something getting the voltage to the arm that's setting things on fire a little more directly.
Old 19th January 2007, 06:12 AM   (permalink)
You can do that with a Tesla coil, never tried it myself (intentionally). High voltage at a high frequency travel the surface of a conductor, not through it. It gives a real creapy feeling, but not painful. Guessing this is what he is doing.
HarveyH42 is offline
Old 19th January 2007, 06:26 AM   (permalink)
Back years ago i made a Solid State Tesla Coil from some simple plans with a TV flyback run at a resonant frequency. Just add some extra windings on the core, a couple of 2n3055's, a few other little components.
Doesn't work very well with new TV flybacks because they cast the HV diode into the flyback and there's no way to get it out. The diode is a problem. The old- OLD- big black-and-white TVs had big flybacks and the diode was in the anode lead.
Oznog is offline
Old 19th January 2007, 09:32 AM   (permalink)
Looks pretty normal what he's doing - he's NOT keeping hold of the EHT cap, he's merely insulating himself from the floor - then charging himself up from the EHT. As such it HAS to be DC, as AC wouldn't work.
We did the same thing at school in the 60's, using a van de graff generator, and standing on a stool as an insulator - the voltage was MUCH higher of course. The voltage is so high that the students hair stands on end, and unfortunately the teacher was talking and waving his arms about and got too close - and there was a 12 inch spark from the students nose to the teachers fingers
Old 19th January 2007, 01:01 PM   (permalink)
Wink
Are you sure its DC?
When I played with a Vandegraff generator, we got over 50KV at DC, but the discharge was very short (perhaps microseconds?), and it took 15-20 seconds to build up another charge.
If you watch the video, he's continuously discharging a spark, so I seriously doubt that its DC, otherwise he would be dead. The current must be conducting through his skin (i.e. the skin effect). Continuous DC would interfere with his heart (unless he's a Vulcan!)
Analog is offline
need an old flyback transformer PhantomRacer Datasheet/Parts Requests 7 28th September 2007 11:50 PM
