Old 16th January 2007, 06:05 PM   (permalink)
Default Electric Fence Voltage
I am fairly new to the electronics scene, and have committed myself to several projects for the pupose of learning. I am attempting to build a tester for my electric fence around our farm, but I'm just not sure how to drop/control the voltage from the controller. I have been told that it is a DC voltage, and I know it's rated at 5kV. If I can get this voltage down into what I would consider a managable range (say, 25v) I could take it from there...
Any guidance would be appreciated.
antksmit is offline
Old 16th January 2007, 06:26 PM   (permalink)
Electric fences generally output a short high voltage pulse, it's probably not something that's easily measured?.
Nigel Goodwin is online now
Old 16th January 2007, 06:48 PM   (permalink)
I have made a number of electric fences for our farm [animals] in
South Africa.
If you ever require to make your own fence, goto a local car breakers
and get a 12volt car ignition coil, the series ballast resistor and the 2mFd
capacitor from the distributor.
Using a simple circuit to switch a relay on and off, say once a second you
can generate a high voltage pulse. The circuit is designed so that you can vary the 'dwell' time of the relay [ how long its closed for, which gives some control over the energy/voltage of the high voltage pulse] and the time interval between pulses. Power it from a 12v car battery.
As a test 'dummy' load I use an old spark plug. A rule of thumb is that a
1kVolt spark will jump across 1mm gap, so if you create a gap of 5mm and the
spark jumps it, you have at least 5kV. Keep opening up the spark gap until
spark fails. This will give you a rough guide.
As the impedance of the ignition coil spark generator is high, it will deliver
very little current and it is not lethal, but uncomfortable. Anyone who
has had a shock from their car ignition will tell you.
Regards
EricG
ericgibbs is offline
Old 16th January 2007, 06:58 PM   (permalink)
I always thought they were more along the line of 10kV. I know they make testers for fences that measure the voltage. Some are digital and some are neon like this one:
http://www.electricfence-online.co.u...hopscr180.html
I neon tester might be easier to make.
Just my advice as a fellow novice, but high voltage dosn't seem like a good starting point. Sure the fence won't kill you, but projects that run off a 9v battery will be easier and less painful.
Andy1845c is offline
Old 16th January 2007, 07:01 PM   (permalink)
South Africa.
Regards
EricG
a TV flyback xfrmr will also do the job.
"Everything that is done in the world is done by hope." -Martin Luther
"There are two ways to live your life. One is as though nothing is a miracle. The other is as though everything is a miracle."-Albert Einstein
Analog is offline
Old 17th January 2007, 10:49 AM   (permalink)
Try to measure with a string of 10 x 10 Mhm: resistors in series,
and have 1 x 1 Mhm: in series too.
So all up you have 11 resistors in series.
At 10 kV you get nearly 1000 volts across each 10 Mhm: resistor.
Across the 1Mhm: resistor you should get about 100 Volts which should be ample to lit a neon indicator ( which usually strikes at about 70 Volts)
Of course have the R's well spaced out on your tester and the 1Mhm: Res. will be at the end of the string with one leg to the ground.
It's not super accurate but it will give you an indication of the voltage level.
Also a neon imposes a negligible burden on the tester. provided it doesn't get too much overvoltage.
The neon striking voltage can be determined with a variable dc supply or mains variac driving a bridge rectifier.
Be cautious with mains wiring during testing of course.
If nothing lights up, reduce the 10Mhm: Res. string to 8 or 6 or less just to get the neon to pulse.
Than work out backwards how to get the fence voltage.
say 70 volts across 1M. and 10 x 10 M Res. about 7000 Volts makes 7700 Volts.
All Resistors rated at 1 Watts
RODALCO is offline
Voltage ElectroMaster Electronic Theory 44 8th August 2007 06:35 PM
Resistors Marks256 General Electronics Chat 52 3rd August 2006 02:00 AM
Voltage reg or voltage reference. Screech General Electronics Chat 4 13th May 2005 07:57 AM
making a voltage / amp tester with a pic 16C711-04 terramir Micro Controllers 10 24th July 2004 11:23 AM
convertion of acvoltage to high dcvoltage panchumarthy Electronic Projects Design/Ideas/Reviews 8 12th December 2003 02:36 PM
