Old 16th January 2007, 10:19 AM   (permalink)
Default EFI Fuel Circuit
Hi All,
I am having a problem with my EFI fuel relays. I have Toyota Corolla. The first day I experienced the problem, my car would not start. I then traced the wire leading to the fuel pump and applied power from the battery and the fuel pump kicked in so this confirmed that the fuel pump stil works. After much troubleshooting, I found following:
1 small 4 pin relay in side the car by the kick panel (circuit opening relay)and another larger 4 pin relay (EFI Main relay) in the engine compartment fuse box.
When inspecting the relay inside the car, I found that it was working. This relay does not have any numbers so I had to open it and check on the inside. When + and - is applied to the coil, you hear a click. So I added an additional + to the (number 30 pin) in the relay and connected a test light to the other pin and it worked. This relay has a resistor across the coil.
I also tested the larger relay in the engine compartment fuse box with the same results.
So I think the relays are not faulty...(could be wrong)
So I went further to the socket where the circuit opening relay plugs into and found the following:
Normally Pin 30 is the pin where direct + is applied but on the socket, this wire runs to the fuel pump.
One side of the relay has + that is bridged to the other pin socket and the other side of the coil has a - which I think is controlled by the ECU. See attached pic.
So I test the theory and connect the same relay as in the car using a test light and the power can get re-routed out on the "number 30" pin.
The car was sent to a couple of auto electricians and the last auto electrician said that the ECU has a burnt track which he showed me. When a wire is run from the ecu to the - terminal on the circuit opening relay, it works, So I need to repair the track on the ECu and test the existing wire that runs to the relay - but I do not think that it was the cause of the problem.
Currently I am running a relay (same spec) connected up. I removed the original circuit opening relay. Took ignition power from the socket for two of the terminals and earth from the body of the vehicle and the last wire runs to the fuel pump. But what happends occasionally is that the EFI main relay fuse in the engine compartment MELTS. This tends to happen when I try to start the car but the key may slip in my fingers and I have to restart. The problem with this setup is that the fuel pump runs when the ignition is set to on.
How it normally suppose to operate is that when the ingition is moved to START, it is suppose to run the fuel pump for a few seconds and then get another source of of power.
I am not sure if all this makes sense to anyone but any help would be appreciated.
we can gmail chat if anyone can assist: akajee@gmail.com
akajee is offline   Reply With Quote
Old 16th January 2007, 05:35 PM   (permalink)
Could you post a schematic of the whole circuit, with indicators of where things are burning out and such? It's hard to visualize from reading text...
i_build_stuff is offline   Reply With Quote
Old 17th January 2007, 06:45 AM   (permalink)
I have drawn a few diagrams, see attached, hopefully this makes sense.
Need help about a 7805 regulator circuit ! Zarkabul Electronic Projects Design/Ideas/Reviews 26 13th June 2005 06:07 PM
HELP! a digital signal to close a circuit fireismyflag Electronic Projects Design/Ideas/Reviews 2 22nd March 2004 10:45 PM
start/stop watch circuit bd13 Electronic Projects Design/Ideas/Reviews 2 21st March 2004 03:06 AM
Circuit functioning very strange. Why? Cyclone Electronic Projects Design/Ideas/Reviews 12 4th November 2003 12:30 AM
On-time delay circuit using LM555 mozikluv Electronic Projects Design/Ideas/Reviews 9 24th October 2003 01:44 AM
