| i've found this schematic circuit... but the problem is..idunno how to read it... ![]() Last edited by an2; 17th January 2007 at 08:41 AM. | |
| The 16F84 is a standard old PIC, you need a PIC programmer to program it - try reading the 'sticky' in the micro-controller forum. Presumably you have the code to program in the chip?. What does the RS232 interface allow you to do?, the 16F84 has 64 bytes of non-volatile memory, perhaps it's for storing parameters there to alter preformance?. | |
| yes, i have the .hex file.. also the .asm of the CDI.. but need to build th PIC programmer hardware first... i've found the simplest Pic programmer in the net.. (if you have some other way please let me know) is it hard to do this device?? i really2 zero about electronic... | |
http://www.mitedu.freeserve.co.uk/Prac/symbol.htm http://www.mitedu.freeserve.co.uk/Prac/readdiag.htm
__________________ --- The days of the digital watch are numbered. --- | ||
| thanks bro!... | |
| uuuuhhh Is it just me or are there no schematics in this thread | |
missing links... sorry.. | ||
| Nigel's supposition is correct. The microcontroller is there to adjust the spark advance according to engine speed. It allows for easy starting and then changes according to speed for more power. The hobbyists use a table look-up for the advance settings. See: http://www.rcuniverse.com/forum/m_4344316/tm.htm In answer to "how does it work," the 400V capacitor connected to the spark coil is charged with rectified current from the alternator, then rapidly discharged through the BT151 SCR , which causes the ignition coil to generate the high voltage (inductive kick) needed to fire the spark plug. The microcontoller provides the pulse needed to fire the SCR. The pick-up is frequently a Hall sensor, which provides timing information to the microcontroller. | |
| Hi dear, I can build the circuit, and I have a pic programmer but don't have the hex code file, if u have it please send me Last edited by DEEE; 17th December 2007 at 06:41 AM. | |
You may want to delete your e-mail address from your original post. John | ||
after build the circuit I'll can send u the result assoonas possible | ||
| any body help me to make cdi .anybody send me diagram on my e.mail adders.this is my adders asif_shah25@hotmail.com | |
| how i can make cdi anybody tell me . | |
| This thread provides a lot of information. What do you not understand? Please ask specific questions. | |
| 50 watt voltage doubler for 6 to 12 volt motorcycle | Zeph | Electronic Projects Design/Ideas/Reviews | 9 | 18th December 2007 03:04 AM |
| Motorbike cdi to PC | an2 | Electronic Projects Design/Ideas/Reviews | 0 | 16th January 2007 09:58 AM |
| 6v/12v Motorcycle Battery Charger | steptoe | Electronic Projects Design/Ideas/Reviews | 10 | 11th September 2006 05:23 AM |
| motorcycle intercom | blue_wave | Electronic Projects Design/Ideas/Reviews | 3 | 9th September 2006 10:44 AM |
| Motorcycle Capacitors | Glyn | Electronic Projects Design/Ideas/Reviews | 6 | 2nd January 2004 02:06 AM |
