Old 15th January 2007, 08:32 PM   (permalink)
Default Trouble understand IR specification
Dear all:
I'm having a little trouble understanding something
For an IR (IR TX and RX) can someone explain what the following is
Frequency Range (Mhz) = ?
stripe (line) width (Khz) = ?
Modulation Type
many many thanks - tj
timothyjackson is offline   Reply With Quote
Old 15th January 2007, 08:41 PM   (permalink)
Frequency range would be the frequency of IR light (ie. the wavelength of light) that a RX is sensitive to. For a TX, this is the range of wavelengths it will emit. Neither RX or TX are perfect so they can't emit, or be sensitive to just a single wavelength of light- it's a small band around a center frequency.
Not sure what stripe width is...sounds familliar. It's a width, but you say the units are in kHz?
Modulation is similar to the RX and TX being switched on and off synchronously at a high frequency. That means the RX is only trying to detect light when the TX is sending light. This makes false triggers less likely to happen (like ambient light can sometimes cause a false trigger).
Old 15th January 2007, 10:50 PM   (permalink)
I suggest you give more details of what you're trying to do?, so far you're making no sense?.
Old 16th January 2007, 12:35 AM   (permalink)
I did a little bit of searching on google and everything I'm finding with a refrence to line width is for infrared spectroscopy. I'm not sure how the receivers work but basically the line width is the sub band of the IR spectrum the specimen absorbs.
straight answer, har har."
Old 18th January 2007, 11:26 AM   (permalink)
OK - definatley helping.
Maybe by strip, i mean beam? - Beam width, does that ring any bells (i guess some "measurablity" of how big the IR beam is (thats being transmitted)
Modulation - I understand PWM, yet, what are the types of Modulation - are there different/generic ways to modulate. I.e. if i asked someone to modulate an ir tx and rx with XX(?) modulation?
thanks tj
Old 18th January 2007, 11:47 AM   (permalink)
Still not really making any sense - why not explain what you're wanting to do?.
Old 19th January 2007, 02:10 PM   (permalink)
aiming to understand 2 things
1 - If IR can be technically specified according to the following factors:
Modulation Type
2 - Exactly what they mean
Old 19th January 2007, 02:21 PM   (permalink)
Still makes no sense - IR is just a certain part of the spectrum, do YOU understand your question if it's altered to read:
1 - If BLUE can be technically specified according to the following factors:
Modulation Type
Old 19th January 2007, 11:24 PM   (permalink)
LED's IR or otherwise don't send out only one frequency, they send out a thin band around a central frequency, the stripe width is basically the cuttoff above or bellow or center of the primary frequency.
Inchworm ICD2 Getting Started Trouble GRC Micro Controllers 0 23rd December 2006 09:15 PM
big trouble with NE564 and XR226 Powerwiz Datasheet/Parts Requests 7 12th August 2006 01:14 AM
What BJT specification do I need to look at for switching time? FusionITR General Electronics Chat 3 9th July 2006 09:46 PM
Trouble programming the config mem on a pic16F628A FlyingDutchMan Micro Controllers 2 25th April 2006 05:11 AM
Specifications Applied Caltech General Electronics Chat 1 25th December 2003 05:00 PM
