| | (permalink) | ||
thanks | |||
| i used the oscilloscope... and only saw a wave something like that... even before the NE567... so the input and output of the NE567 i obtain is the same... just differ in magnitude... | |
| That looks like bursts of RF, which is what you would expect from a crude AM transmitter. The NE567 needs to be tuned to the modulating frequency. | |
so how am i suppose to tune the NE567??? by the way, thanks alot for helping | ||
| well, i tried many ways, including tuning the variable resistor... and the result is still the same... thanks to Audioguru and RON H who taught me how to modify it, i managed to pull up the output voltage of the NE567 from 1mV to 3mV ( i donno how it happened)... but still not enough to trigger the relay... Last edited by chinsoon; 23rd January 2007 at 01:11 AM. | |
| I have everything connected as shown in the figure. I even changed the NE567 to make sure that the problem is not the IC. but the results remains the same. That is why i hope to find out there is there any other factors that will affect my output... my problem now is that i can see difference of the output of the NE567 before and after i turning on the transmitter, but the difference just isnt enough to trigger the relay. Any suggestion how to overcome this? or any idea why is this happening? | |
| Your first schematic has a missing resistor in series with the base of the BC307 transistor that causes the output transistor of the NE567 to blow up and maybe also the base of the BC307 to blow up. The output of the NE567 is the collector of an NPN transistor that is trying to go to ground but the base of the BC307 is holding it at 0.7V less than the positive supply with a very high current. The BC307 is also missing a resistor to turn it off. The BC307 might not be required since the output of the NE567 can drive a 100mA load (that is connected to the positive supply) directly. The circuit is missing a diode across the coil of the relay to arrest the inductive voltage spike produced when the relay turns off. The capacitor at the output of the NE567 is not recommended.
| This device operates at 27 MHz right? What's the purpose of the tank circuit of the transmitter (39 pF and L2)? And is the modulatind signal coming from the 555 timer which is 584 Hz?
__________________ Superman returns.. | |
actually that was my question as well... still do not understand why is it there... but it seems like its a path for the RF current to radiate... yes... 27MHz.. and the frequency of the 555 timer is 580HZ... | ||
Talking about that, i changed the transistors and also the NE567... but i still cant get the output... and i took away the capacitor like what u said, and follow the diagram that you posted that day.... is there any other possibility that cause this? | ||
| When the NE567 has an input signal of 20mV at its input that it is tuned to, then its output will go to ground. It says in the datasheet.
| Pin 8 og the NE567 is the collector of a NPN transistor, u need to pull up to Vcc via the coil of the relay and with diode protection. When it receives signal, the transistor sill conduct and switch the relay, when there is no signal, pin 8 should be measured as high as Vcc and the relay is not switched. What I don't understand is the RF part, what is the purpose of they crystal? Then how about the tank?
| opamp TLO-82 datasheet needed | dudeshan | General Electronics Chat | 8 | 28th October 2007 03:20 AM |
| Theodolite Design Feedback Needed | bobledoux | Electronic Projects Design/Ideas/Reviews | 0 | 6th August 2006 04:22 AM |
| Onboard diagnostic system help needed | RK NAIR | Electronic Projects Design/Ideas/Reviews | 11 | 18th November 2004 05:28 PM |
| PIC16F877 ADC problems, urgent help needed | grutt | Micro Controllers | 6 | 1st April 2004 04:07 PM |
| Circuit Needed Please | jkon | General Electronics Chat | 2 | 19th December 2003 02:39 AM |
