Old 8th January 2007, 04:15 AM   #1
Default Potentiometer with click at 0
Gday,
I am looking for a special potentiometer. The item i am looking for is often found on volume controls on mini radios and CD players. When you turn the volume down as far as it goes, you can feel the wheel click and the radio turns off.
Does such a item exist to a hobbyist?
Regards,
Mitch
m1tch37 is offline
Old 8th January 2007, 04:48 AM   #2
You want a pot with a switch on it. They are commonly available. The switch is not electrically connected to the pot - only mechanically.
Ron
Roff is offline
Old 8th January 2007, 06:15 AM   #3
the click is sometimes called a detent too. like a pot for a balance control has a center detent between left and right, it's accomplished the same way, with a little addition to the shaft of the pot - could also be done with a notch in the shaft, a spring and a small bearing. when the notch aligns with the bearing, the spring pushes it in, slightly locking the shaft, so you have 'feedback'
If you don't have a planet, what good are gold bars?
want to contact me directly? gmail gordonthree
check out my project website: http://projects.dimension-x.net
Favorite numbers:
09 F9 11 02 9D 74 E3 5B D8 41 56 C5 63 56 88 C0
justDIY is offline
Old 8th January 2007, 08:10 AM   #4
Yep thats it, i just didn't know the right terminology.
Thanks for your help.
m1tch37 is offline
Old 8th January 2007, 03:19 PM   #5
i want to know the pot u had shown is which type of pot? is it resistance wound pot or which type????
kpsoneji is offline
Old 8th January 2007, 04:10 PM   #6
A detent is not going to turn off the radio. You need a switch. I don't believe I've ever seen a pot with a single detent at one end of the rotation.
Ron
Roff is offline
Old 8th January 2007, 04:17 PM   #7
This site has a list of different types of resistance elements. You can probably buy any of them with a switch mounted on them.
I don't know what kind of element the one in the picture has. I found it by doing a Google image search for "pot with switch".
Ron
Roff is offline
Old 8th January 2007, 09:19 PM   #8
Judging by the picture it looks like a carbon track element, noisy and not too reliable but cheap.
if I know the answer.
Hero999 is offline
click, potentiometer
pins explain? motorized potentiometer..? Ctrl_Alt_Del General Electronics Chat 1 6th July 2005 12:05 PM
Miniature Rotary Potentiometer: Does it exist? DigiTan General Electronics Chat 12 13th January 2005 03:53 AM
How do I wire a potentiometer? AwwsChwA Electronic Projects Design/Ideas/Reviews 3 14th April 2004 03:15 PM
Networking Harddrives crazymonkey General Electronics Chat 3 9th March 2004 05:55 PM
How do I generate a potentiometer output? klick General Electronics Chat 3 23rd November 2003 03:26 PM
