| | #46 |
Tektronix has used tantalums in their equipment since around 1970, usually as bypass caps in an RC circuit with maybe a 10 ohm resistor between supply and cap/load and for timing caps for low-freq/long PW one-shots and timers. Tantalum caps didn't fail any more often than ICs, transistors or diodes. A company like that doesn't intentionally use unreliable components and if they do find that a component is unreliable, will quit using them and issue a modification order to swap out any that come into a service center. In my hobby work, I've never had a tantalum failure. Dean
| | #47 | |
I haven't had any problems with tantalums. I thought they wer more reliable than electrolytics until I came here. Perhaps it's just that one manufracturer produced a load of poor quality components.
__________________ I do not answer private messages asking for help because no one else can: benefit from advice I may give or correct me if I'm wrong. Please ask on the open forum if you have a question and I'll be happy to help, if I know the answer. | ||
| | #48 | |
That problem has nothing to do with tantalums but rather his lack of understanding what is actually desired in his system (impedance -wise) The context of our discussion is around the reliability aspect. Performance is what seems they are after. Impedance is impedance whether is comes from AL-elec or Tant-elec or ceramic for that matter. | ||
| | #49 |
up for more
| | #50 | |
No, you've got it wrong Tantalum capacitor has an ESR ten times better than that of electrolytics On a previous comment by someone else, informities that develop/part of the manufacturing process actually 'self fill' and hence they never loose capacitance, therefor its not just their shelf life, but their operating life that is considered 'infinite'
__________________ digital-diy.com - Hobby microcontroller projects and tutorials. Assembly, PICBasic and C examples. Last edited by gramo; 7th January 2007 at 07:47 AM. | ||
| | #51 |
You misread my statement, electrolytics have a higher equivilant series resistance, so in pulse charging and discharging applications they will self limit their own charge/discharge rates because of the inherant resistance. A tantalum cap because of it's better (lower ESR) doesn't 'self limit' it's current. EL's and tants might have similar ripple current ratings, but a significantly lower ESR for the tant would make it more prone to self destruction from instantanious pulse heating when it was used in a low impedance situation (such as a filter cap which is usually connected via a VERY low ohmic connection to ground) Out of every post I've read so far that's the only thing that makes sense to me. If someone knows something else they better start spilling the beans =>
__________________ "Because I be what I be. I would tell you what you want to know if I could, mum, but I be a cat, and no cat anywhere ever gave anyone a straight answer, har har." Last edited by Sceadwian; 7th January 2007 at 06:42 AM. | |
| | #52 |
I wouldn't agree, if the ESR is lower then the power dissipation will also be lower and it's the job of the designer to ensure that the ripple current isn't exceeded which isn't a hazard in 99% of applications anyway. Overcurrent is only a probelm when a capacitor is used as a mains frequency smoother in a power supply, when connected in series with a speaker in an audio amp or used in power factor correction - a 10µF capacitor isn't going to have it's ripple current rating exceeded however low its ESR may be.
| | #53 |
I just thought I'd post since this is so old and Nigel could be misleading people looking for answers about tantalums. Maybe back when dinosaurs roamed the Earth when you were using them they were unreliable, but today they are very reliable. No less than five times have I taken apart a device certified for use in life support applications to find them littered with tantalums. I used them in college for statistics experiments to verify the claimed reliability of the manufacturers only to find every single time that it was right. Trials were conducted over several months with varying as well as extreme temperature and voltage gradients. I even attached a picture of an RC receiver using tantalums. This module has been in service for several years in the bitter cold and blistering heat. I'd say it was a fluke if I knew as little about tantalums as you seem to but the reality is that they are better devices than their aluminum electrolytic counterparts in many applications. Your inability to get past your ego is quite irritating when all of the facts point the other direction from your opinion. That is not how science works. /rant Last edited by bigsmooth; 15th April 2009 at 03:21 AM. | |
| | #54 |
I Agree, I use Tantalums in almosty all the projects on my website and have Never had a probem with them. Gary
__________________ I No Longer accept Private Messages on here. All Emails to me Must Contain the Word \"Electronic\" in the \"Subject Line\" or they go Directly to my Junk Mail Folder. Email me at: chemelec@hotmail.com Website: http://www3.telus.net/chemelec | |
| | #55 |
| | #56 |
I seem to be using electrolytic more often then not now days as they are cheaper and the AUD -> USD has been pitiful for quite some time
__________________ digital-diy.com - Hobby microcontroller projects and tutorials. Assembly, PICBasic and C examples. | |
| caps, electrolytic, tantalum |
| Good Electronic Supply's Sites, Everyone Come On In! :P | Electric Rain | General Electronics Chat | 44 | 28th August 2007 12:06 AM |
| Power Filter Caps, how do you know how big they should be? | joecool85 | General Electronics Chat | 6 | 10th April 2006 03:23 AM |
| Electrolytic caps and heat | Screech | General Electronics Chat | 5 | 12th May 2005 08:30 PM |
| Huge Cap's | bryan1 | General Electronics Chat | 9 | 30th January 2005 08:41 PM |
| Reversing tantalum caps | Oznog | General Electronics Chat | 9 | 21st August 2004 09:35 AM |
