| | #31 | |
| | #32 |
Nigel, I think that you'll never choose tantalum capacitors!?! | |
| | #33 | |
| | #34 |
As I said, I always use them after 5 V LDO regulators, that require a low ESR. 10 uF - 16 V tant caps are cheap and I find them easily. As I don't know exactly the ESR of my aluminum caps, I prefer to avoid failures! | |
| | #35 |
Nigel Goodwin, Since your mostly opposed to Tantalums, Here is Something else you might Consider when using Electrolytics. The Physically Bigger the cap is, Generally speaking the Lower its ESR is! So for two caps of the Same Voltage and Capacitance, if you Need Low ESR, Use the Bigger one. Actually, Testing my Tantalums on my "Sencore LC102", Capacitor/Inductor Analyser, this also holds true for these types. "Physically Bigger is Better in this way". If you Have the Room. Also, Testing a lot of NEW Electrolytics that I have just Bought, I find most of them FAIL for the ESR Test.
__________________ I No Longer accept Private Messages on here. All Emails to me Must Contain the Word \"Electronic\" in the \"Subject Line\" or they go Directly to my Junk Mail Folder. Email me at: chemelec@hotmail.com Website: http://www3.telus.net/chemelec | |
| | #36 | |
I'm also somewhat dubious about using components with have a specific rating, then a warning in the datasheet not to exceed 1/3 of that rating - it seems a poor way to specify a component!. | ||
| | #37 | |
| | #38 | |
Also generally, de-rating components will improve the longevity no matter what the compopnent. So if the tantalum manufacturers are putting de-rating warnings into the dataheets, consider it a blessing. When was the last time you saw an aluminum electrolytic datasheet that read: CAUTION: The electrolyte in this capacitor will dry out over time and cause the component to fail. It will likely be the most unreliable part in your design. Please de-rate generously to imporve longevity. Enjoy! | ||
| | #39 | ||
| | #40 | |
Admittedly electrolytics are troublesome - but less so (in my experience) than tantalums - certainly far more reliable compared to where the tantalums historically failed. Small electrolytics used as supply decouplers on PCB's hardly ever fail - tantalums did. Where electrolytics fail big time is in switchmode PSU's!. | ||
| | #41 | |
| | #42 |
Yes, and you also need to know what charicteristics are required for your application For example, ripple current is important when using a capacitor as a smoother on a power supply but unimportant in a timing capacitor.
| | #43 |
It sounds like one of tantalums advantages 'low esr' is it's biggest failing point as well? Electrolytics would self regulate their current because the ESR is higher? Am I getting the rough idea here right?
| | #44 | |
I'm not sure who "domestic mfgs" are nowadays since virtually everything is outsourced, but mfgs DO widely use them. They tend to be a bit more expensive and less available in throughhole pkgs. Mfgs care a LOT about cost. So big stuff (TV sets) probably won't use them. They're like gold to MP3 player, hard drive, laptop motherboard designers. The lifespan of a tantalum cap is generally regarded longer than an aluminum electrolytic. I get the idea its window of expected lifespan and ESR rating is easier to anticipate too.
__________________ I thought what I'd do was I'd pretend I was one of those deaf-mutes. | ||
| | #45 |
what do you think of this? http://indyguitarist.com/forum/index.php?topic=143.0 | |
| caps, electrolytic, tantalum |
| Good Electronic Supply's Sites, Everyone Come On In! :P | Electric Rain | General Electronics Chat | 44 | 28th August 2007 12:06 AM |
| Power Filter Caps, how do you know how big they should be? | joecool85 | General Electronics Chat | 6 | 10th April 2006 03:23 AM |
| Electrolytic caps and heat | Screech | General Electronics Chat | 5 | 12th May 2005 08:30 PM |
| Huge Cap's | bryan1 | General Electronics Chat | 9 | 30th January 2005 08:41 PM |
| Reversing tantalum caps | Oznog | General Electronics Chat | 9 | 21st August 2004 09:35 AM |
