Old 1st January 2007, 02:35 AM   (permalink)
Default delay off ....... then on
I just made up a test circuit using an LM555 ic. It lights an led for approx. 6-7 seconds then goes out. What I need it to do is delay those 6-7 seconds then pulse on long enough to trow a latching circuit using a dpdt signal relay (.2 sec or so). Im trying to figure this out and I know its simple enough, just cant think of how. Anyone have any ideas?
here is the circuit I used.
http://www.doctronics.co.uk/images/555_11.gif
captnstoed is offline
Old 1st January 2007, 02:58 AM   (permalink)
You need two 555s, one for the delay, the 2nd for the 0.2sec pulse.
Russlk is offline
Old 1st January 2007, 03:43 AM   (permalink)
fo course ... thanks, I'll give that a try. Is there another ic I could use that could do both functions?
Old 1st January 2007, 04:42 AM   (permalink)
Hi, Use 556. it is two 555s ina single pack
Regards,
Sarma.
mvs sarma is offline
Old 1st January 2007, 08:27 AM   (permalink)
Here's a great IC to solve your problem:
12F509 ... less than buck each, and requires no external components, aside from some glue depending on what you're switching.
If you don't have a planet, what good are gold bars?
want to contact me directly? gmail gordonthree
check out my project website: http://projects.dimension-x.net
Favorite numbers:
09 F9 11 02 9D 74 E3 5B D8 41 56 C5 63 56 88 C0
justDIY is offline
Old 1st January 2007, 11:47 AM   (permalink)
You could grab the lite version of proton+ and make life damn easy with a couple of commands, im not sure if this is exactly what you want, but its easy to modify (you can use any 16F series pic really, most are cheap and great, but theres a few that out perform others)
PHP Code:
Device
16F876A        ' Declare the device being used
Xtal = 4                 '
Crystal Speed
ALL_DIGITAL
True        ' Make all outputs digital
TRISA = %00000000        '
Make all of porta outputs
PORTA
= %00000000        ' Set them all low
Symbol LEDS = PORTA.0    '
The compiler will now change LEDS to PORTA.0
Symbol Relay
PORTA.1    ' and Relay to PORTA.1 whenever they are used now
Main:                         '
Start of program
     LEDS
1            ' Turn on the LEDS
     Delayms 6000        '
Delay for 6 seconds
     LEDS
0            ' Turn them off
     Relay = 1            '
Turn on the relay
     Delayms 200
' Delay for 0.2 Second
     Relay = 0            '
Turn the relay off
     Goto Main
Do it forever
Spency.
PIC Micro's - Your mind is the limit
PIC's and interfacing with other devices - a PIC Basic Guide @ digital-diy.net
gramo is offline
Old 1st January 2007, 12:42 PM   (permalink)
Hi Gramo,
I am sorry to hijack this post but i was curious to know what language that code is for. I am studying microcontrollers atm and learning assembly. It looks like a higher level langauge just wondered which one.
Cheers
Andy
UPDATE: doh (homer simpson voice)...... just noticed its PHP
Originally Posted by gramo
PHP Code:
Device
Xtal = 4                 '
Crystal Speed
ALL_DIGITAL
TRISA = %00000000        '
PORTA
Symbol Relay
Main:                         '
Start of program
     LEDS
     Delayms 6000        '
Delay for 6 seconds
     LEDS
0            ' Turn them off
     Relay = 1            '
Turn on the relay
     Delayms 200
     Relay = 0            '
Turn the relay off
     Goto Main
Do it forever
andy257 is offline
Old 1st January 2007, 12:48 PM   (permalink)
no, its not PHP, i just use php 'quotes' as they dont take all the tabs/extra spaces out for the remarks that you throw in after commands, i.e.
Test ' Remark
PHP Code:
Test           Remark
Its all written in Proton+, you can download the lite version, but it restricts you to 50 lines of code - still plenty to use for small apps.
Spency.
gramo is offline
Old 1st January 2007, 12:55 PM   (permalink)
Its really powerfull, and after a quick look through the help file you'll see just how much diversity the program has, and it doesnt stop at math, its the ease of use to interface with almost everything on the market today from LCD's to servos to almost any serial interface.
They have a user forum aswell that really has a great support network
Spency.
gramo is offline
Old 1st January 2007, 01:23 PM   (permalink)
thanks for that Gramo. Trying to become experienced in assembly but once i have mastered assembly i will convert to a higher language for the more complex circuits.
andy257 is offline
Old 1st January 2007, 01:41 PM   (permalink)
Why not just use the 'Code' tag? - it's even on a button '#' on the Advanced entry setting.
Old 1st January 2007, 02:05 PM   (permalink)
Nice, Never noticed, I'll keep that in mind!
Spency.
gramo is offline
Old 1st January 2007, 02:35 PM   (permalink)
Ok, Ive got the desired outcome using two 555's because thats what I have on hand.
On this PIC topic, how difficult is it for someone new to this, to get up and running? For instance, here are a few porjects I need to develop
1. @ the push of a button, set delay of 5 seconds, then random delay of 0-5 seconds that pulses a relay.
2. an IR Transmitter (just a beam) that works over 10 feet. Im looking at 38khz mod and pulses of 1400hz to be "seen" by the IR module.
3. A stopwatch with a large LED display to be used as a timer from point A to B.
Would it be worth while to learn PIC'S for all this? I am new to electronic components but learning quickly.
Is there anyone out there who devolops prototyes like this?
Thanks for all the help.
Old 1st January 2007, 02:56 PM   (permalink)
Pics are fantastic, they can do all you need and much more besides.
Have a look at Nigel's tutorials.
House0Fwax is offline
Old 1st January 2007, 03:00 PM   (permalink)
Given the outcomes you want, I'd say PICs would deffinetly be worth looking into, but you still have to consider;
* Buying/Building a programmer (Fairly cheap)
* Getting a Development suit like Proton+/other higher level ones or Learn to bit crunch with Assembler
* And finially you will have to buy PIC's and other peripherals like crystals
Heres a basic list from futurlec.com.au (prices are in australian, goto futurlec.com for $US)
Spency.
gramo is offline
Stepper motor control with PIC16F84A netbug Micro Controllers 71 30th August 2008 01:07 PM
Log Data using pic16F877A williB Micro Controllers 32 31st October 2006 10:28 AM
Random Numbers for PIC PDubya Micro Controllers 12 8th July 2006 11:01 PM
Delay routine not working gregmcc Micro Controllers 6 18th September 2005 06:23 PM
Effects stephenpic Micro Controllers 6 19th January 2004 12:57 PM
