+ Reply to Thread
Results 1 to 10 of 10
Thread: Anyone know what this part is
  1. #1
    mramos1 Excellent mramos1 Excellent mramos1 Excellent mramos1 Excellent
    Join Date
    Sep 2005
    Location
    Boynton Beach, Florida USA
    Posts
    2,257
    Default Anyone know what this part is
    I am attempting to repair an emergency light. Why as they are so cheap? I have many of them with the same problem. If I can repair one, I can repar many more. And they are a weord size where wallpaper has been cut around them, and painters have painted around them
    I have tested all the descretes, the relay. All checks good.
    It has a T106Y41 on it. I have no tested that (it is about all that is left).
    Does anyone have the pinout or know what it is? If I search for it, it is all over for sale, and no spec sheets that I have found so far.
    Thanks.. And Happy New Year.....
  2. #2
    Join Date
    Nov 2003
    Location
    Derbyshire, UK
    Posts
    29,783
    Try posting a picture of the board.
  3. #3
    epilot Newbie
    Join Date
    Jul 2005
    Location
    middle east
    Posts
    486
    Quote Originally Posted by mramos1
    I am not sure but you can chek the following:
    http://www.alldatasheet.com/datashee...T106-1300.html
    perhaps it is a Fast Recovery Silicon Power Rectifier
    anyway a pic would help as Nigel said
    Good judgement comes from experience, experience comes from bad judgment
  4. #4
    fingaz Newbie
    Join Date
    Aug 2006
    Location
    DERBYSHIRE, UK
    Posts
    265
    Found this if it's any help. . .
    Part Number: T106Y41
    Desc: Sen Scr 30V 4A 200ľA TO202
    http://www.datasheets.org.uk/specsheet.php?part=T106Y4
    'Intellectuals solve problems. . . Geniuses prevent them.' . . . Albert Einstein
  5. #5
    chemelec Good chemelec Good chemelec Good chemelec Good
    Join Date
    Apr 2004
    Location
    B.C. Canada
    Posts
    1,078
    So, If this part has only Two Leads, its probably a Diode.
    If it has 3 leads, its probably an SCR.
    My Guess from what I found in my search is its an SCR.
    (Possibly simular to a tIC106B)
    Quote Originally Posted by fingaz
    I No Longer accept Private Messages on here.
    All Emails to me Must Contain the Word \"Electronic\" in the \"Subject Line\"
    or they go Directly to my Junk Mail Folder.
    Email me at: chemelec@hotmail.com
    Website: http://www3.telus.net/chemelec
  6. #6
    Join Date
    Sep 2005
    Location
    Posts
    2,257
    Quote Originally Posted by chemelec
    Yes, it is looking like an SCR (3 pins and a TAB that is the center pin). I will see how it comes into play.
    The battery charge circuit is charging, the test button fires the relay. I will have to see what the SCRs part is. I ran out of playtime, had to install a washer and dryer for the wife. But tomorrow I will give it one more go and worse case tell the boss "$20 and you can but a new one". We can put a larger back plate to cover the wall paper
    Thanks to all for the help. Would have never though an SCR but I bet that is it.
  7. #7
    philba Good philba Good philba Good
    Join Date
    Mar 2006
    Location
    Seattle
    Posts
    1,887
    Assuming that the batteries are good (that was my first guess when you said "many have the same problem"), there is likely some sort of design flaw. Replacing the failed component will probably not resolve the design flaw. Unless you can figure out the flaw, it makes more sense to get new ones. Emergency gear needs to have very high reliability.
    edit: new ones == new units of a different design!
  8. #8
    Join Date
    Nov 2003
    Location
    Derbyshire, UK
    Posts
    29,783
    Unfortunately, from the price he quoted, the new ones don't sound like they will be any better? - the influx of cheap junk from China has killed off better quality products in many applications!.
  9. #9
    Join Date
    Sep 2005
    Location
    Posts
    2,257
    These are old US units (not 100%, nothing is).
    The $20 one will be China and be disposable I am sure. Our electrical people told me it was a waste of time for the $20 to replace them (now add the price for the electrician), but I thought I would try to save wallpaper work as well (since they have a larger base) and it is an entire floor of them that most seem to all have the same problem. And a good friend is the owner.
    I did not mention they are all from 1 floor of the building that is being re-built for a new tenant..
    Well, I went through all I could and it should be working far as the descretes, but no output to drive it. Then I though, like the obvious battery (Philba) what would be another easy thing to check (I did not check them as there are two and what are the chances). Bad bulbs.
    Turned out both bulbs are shot. Shorted no less not open.
    My thought on this is maybe they killed power to that floor when the old tenant left and the units cut on and burned out the bulbs and kill the batteries. Not sure why the bulbs shorted but I will check a couple more tomorrow when I (sniff) return to work from the holiday.
  10. #10
    Join Date
    Apr 2004
    Location
    B.C. Canada
    Posts
    1,078
    Quote Originally Posted by philba
    If it is a Design Flaw and I had these devices, My personal challange would be to trace out the circuit and Find the Flaw. More than likely it is just an Under-Rated Part.
    Than correct it so it doesn't happen again.
    Other than Time, (Which can be Fun and Educational) the actual Repair or modifications, probably costs less than the cost of new units that may be no better.
    Years ago, Working at Sears, There was one particular product. Every one had a the same Tantalum Capacitor put in Backwards. Only running at a Low Voltage, it would last a few months, than Short out. Once I found the problem (one hours work), the replacement was Quick and cheap, compared to buying a new one.
    Well that my 2 cents worth.
    Seasons Greetings.....Gary
+ Reply to Thread
  1. Help identify a part
    By thefranchise in forum General Electronics Chat
    Latest: 12th July 2006, 02:01 PM
  2. schottky diode
    By rookie in forum General Electronics Chat
    Latest: 22nd April 2005, 05:13 PM
  3. What would you call this part?
    By TV-Engineer in forum General Electronics Chat
    Latest: 7th April 2005, 04:59 AM
  4. How can i identify the part number
    By zofiof in forum Datasheet/Parts Requests
    Latest: 4th July 2004, 11:50 PM
  5. Replacement Part??
    By tml1220 in forum Electronic Projects Design/Ideas/Reviews
    Latest: 23rd May 2004, 10:01 AM
Tags for this Thread
