Old 27th December 2006, 08:48 AM   (permalink)
Default what exact volt n amp need to charge
what exact volt n amp need to charge a 6 v 4A or 12 V 5 A battery.
'if u cant beat him then join him' I always say...
mamun2a is offline
Old 27th December 2006, 08:50 AM   (permalink)
Depends on the battery type doesn't it?
dknguyen is offline
Old 27th December 2006, 08:51 AM   (permalink)
who knows ?
mamun2a is offline
Old 27th December 2006, 09:11 AM   (permalink)
I'm not sure why you keep putting the smiley faces, but I'm a bitter person and it's starting to piss me off when I see toothed smileys where they don't belong.
I'm saying right now, it depends on the type of battery.
dknguyen is offline
Old 27th December 2006, 10:16 AM   (permalink)
lead acid or motor bikes battery:~
mamun2a is offline
Old 27th December 2006, 03:05 PM   (permalink)
Have you ever seen a 6V or 12V Ni-Cad or Ni-MH or Li-Ion battery???
audioguru is online now
Old 27th December 2006, 03:37 PM   (permalink)
Yes, i saw when i was sleeping. I see it(6V Ni-Cad) in my dream, it was connected with Cellular mobile. Mobile dimension was (Length=12, width=1.2 hight=1) in inches
Ayne is offline
Old 27th December 2006, 07:37 PM   (permalink)
If it's lead acid it shouldn't be overly fussy about the current you put into it (ie. it won't explode like a Lithium battery as long as the current is within reasonable limits). If you google you can probably find some rough numbers. I would be more concerned with knowing when to stop the charge.
dknguyen is offline
Old 28th December 2006, 04:31 AM   (permalink)
i said car or motor bike battery also u funny guys...
mamun2a is offline
Old 28th December 2006, 04:37 AM   (permalink)
mamun2a is offline
Old 28th December 2006, 06:49 AM   (permalink)
Any equivalent or higher voltage will charge the battery.
And .. Keep smiling but be serious...
Aily
Aily Sajjad is offline
Old 29th December 2006, 06:13 AM   (permalink)
Aily, i'm charging my 12 v 5+ Amp Exide motor bike battery with 12 V 300 ma adaptor, about 24 hour is it right?
as far i know the professinal charging stores uses a large size charger and they charge batt 6 V to 24 V within 2-4 hour, what they do?
as from ni-cad's body instruction i know a batt to charged with its 1/10 of current and exact volt, but is it applicaple for car battery???
mamun2a is offline
Old 29th December 2006, 06:23 AM   (permalink)
Car batteries are lead-acid so they are less fussy than NiCds. It means that you can follow the NiCd rules and nothing bad will happen (but you could probably increase the current if you wanted to).
dknguyen is offline
Old 29th December 2006, 11:19 AM   (permalink)
Yeah,
What happens when you start charging is : Initially there is a large current as the voltage of battery is low. As the battery gets graually charged, the battery voltage (which opposes the charging voltage) increases and thus the charging current decreases. Battery Chargers are basically current regulators which provide constant charging current to battery and provide security such as over-charging protection etc.
Just keep an eye on the adapter. If it heats up when you start charging, you will have to use some more powerfull adapter. But i dont think it will be like that. So you can go ahead with what you have.
Aily
Old 29th December 2006, 08:58 PM   (permalink)
For lead-acid, you can't go wrong if you use standard LM338T or LM338K as in the application notes for linear voltage regulator (just heatsink the 338 properly). Pre-set the voltage for between 13.8V and 14.5V (typically 14.2V). The LM 338 is a 5A (guaranteed) device with built-in current limit. You'll need a DC voltage which is at least higher than 14.5V + 1.25V as an input into the regulator. This means about 16VDC or higher.
JTECH is offline
2 Volt SLA battery charger help? czwalga Electronic Projects Design/Ideas/Reviews 7 17th July 2007 10:59 PM
Battry charge cut & on Rakesh Sharma General Electronics Chat 4 2nd January 2005 04:07 AM
6 volt battery regulator thespook Electronic Projects Design/Ideas/Reviews 9 6th September 2004 10:27 AM
Charge Amplifiers newb Electronic Projects Design/Ideas/Reviews 1 7th May 2004 01:42 PM
charge amplifier wat and how? newb General Electronics Chat 0 5th May 2004 05:48 PM
