| Hi everybody, I'm trying to understand mesh analysis, (sometimes referred to as loop analysis) or the mesh current method. "It usually involves fewer unknowns and equations than nodal analysis, and does not use Kirchhoff's current law, making it simpler." taken from: http://en.wikipedia.org/wiki/Mesh_analysis Why doesn't Mesh analysis use current law? | |
| Mesh analysis doesn't use current because the sum of the currents around the loop just doesn't make sense. If it's a single isolated loops the current in one side of the loop IS the same current flowing in another side of the loop. Another reason (and another way to think about it) is that currents can branch off into "adjacent" loops at T-intersections and X-intersections at the nodes sitting on top of the sides of the loop. Therefore the current in each of the 4 sides of a rectangle loop (or however many sides) are not necessarily equal unless it is an isolated loops. That is, the current can branch off into adjacent loops one side of the loop, and only the remainder of that current moves on to the next side of the loop. The sum of voltages around a loop however, equal to zero, since, obviously the voltage at a certain point in the circuit is still the same if you start travelling from that point around a circle back to that same point. So while loop analysis does not use Kirchoff's Current law, it does use Kirchoff's voltage law. I haven't use nodal analysis since I learned it because, although it made perfect sense while it was being taught, when the homework and exams came around I always ended up with like 50 equations. Heh, I've only recently discovered that you only make equations for the junctions (nodes with >2 connections) and not every single node in the circuit. lol. Needless to say, because of that I've never used nodal analysis for anything useful- always mesh. Last edited by dknguyen; 15th December 2006 at 11:57 PM. | |
| It uses Kirchoff's voltage law instead of Kirchoff's current law, so it's really not any simpler. obviously your choice of mesh and node analysis depends on the circuit, and since your only goal is to come up with enough equations to solve for the unknowns, use whatever gets you there faster, whether it be mesh, nodal, or a combination of the two. They're both pretty basic methods, so if you're choosing one or the other based on how "hard" you find each one to be in general, you probably need to spend more time practicing, because they should both be absolutely second nature if you're going on to later electronics courses.
__________________ EEgeek.net | |
| A book in circuit analysis | afesheir | General Electronics Chat | 4 | 4th November 2006 09:09 AM |
| why are sinewaves used for phase analysis? | konzen | General Electronics Chat | 2 | 22nd March 2006 05:12 AM |
| op amp node voltage analysis | SeanHatch | General Electronics Chat | 6 | 18th November 2005 04:23 PM |
| Site to practice circuit analysis? | DigiTan | General Electronics Chat | 5 | 18th July 2005 09:26 PM |
| system analysis | ypg50 | General Electronics Chat | 0 | 22nd November 2004 08:06 PM |
