Old 14th December 2006, 11:24 AM   #1
Question P1 plug stereo to rca(stereo)
Hi, I need some help to weld a p1 plug stereo to rca stereo. I need a diagram(+ and left/right signals). I know the rca plug connector(+ and - diagram), but I doŽnt know the p1 diagram to weld. I need complete diagram schematic.Thanks...
asiatico is offline
Old 14th December 2006, 02:20 PM   #2
I've no idea what a P1 plug might be?. Presumably it's something specific to your country?, but as you don't have your location filled in we don't know where that might be?.
Old 14th December 2006, 02:37 PM   #3
I'm thinking P1 is the reference designator for the connector you want the diagram to. You need a part number.
vortechs2k is offline
Old 14th December 2006, 02:55 PM   #4
I don't know what a "p1" plug is either.
Perhaps you may find the info you need on the "Hardware book" website:
http://www.hardwarebook.net/
picasm is offline
Old 14th December 2006, 06:47 PM   #5
Default Hi
I Need Some Help To Build A P1 Plug Stereo To Rca(ipod Phone To Rca)
Thanks...
asiatico is offline
Old 14th December 2006, 07:22 PM   #6
No, what you need is to read the replies people write to you.
There is not P1 plug, it's a reference designator. What you need is an audio plug like the one here:
http://www.cui.com/pdffiles/CA-254CS.pdf
Or it could be slightly different, you tell me.
The pin-out for this one is:
A- Left Audio
B- Right Audio
C- Audio Ground
D- Not needed for your purposes.
Old 14th December 2006, 07:29 PM   #7
Does the plug look like a 1/8th inch stereo phone plug?
The cable with it to two RCA plugs is sold at The Dollar Store.
audioguru is offline
Old 14th December 2006, 08:38 PM   #8
Must not be enough replies here for him to go by since this topic is posted in another forum!!
HiTech is offline
Old 15th December 2006, 12:33 PM   #9
Question 15 pin VGA to RCA
I need a diagram schematics to make a 15pin vga to rca output(Computer to video/tv). Thanks...
asiatico is offline
Old 15th December 2006, 02:19 PM   #10
A TV won't work from a VGA signal. You need a video card that converts VGA to the type of TV format used in your country.
Old 15th December 2006, 02:19 PM   #11
If you're capable of locating this forum, it's even less effort to enter HD-15 to RCA Adaptor into your web browser! Doesn't anyone do things for themselves anymore? Here then, you sit back in your comfy chair with a cup of coffee, while I do the research for you! BTW, you better have good soldering and cable prep skills to reliably construct an adaptor that involves an HD-15 connector. A professionally made adaptor sells for $20 (US) and one is pictured below.
I gather what you desire is labeled as HD15-3RCA:
this cable will not work to connect the VGA output of a computer to a
TV's yellow, red and white RCA connectors or to the red, green and blue RCA connectors.
If you are trying to feed VGA to a standard television set you'll need a converter module like the one shown here: http://svideo.com/vga2video2.html
If you desire to make your own adaptor, then here are the HD-15 pinouts and you can simply solder shielded wire between the appropriate pins to RCA plugs. Here is the link that explains how in detailed steps: http://www.myhometheater.homestead.com/vgacable.html
VGA Video connector pinouts:
Pin # - Signal Name - CAT 5 Conductor
1 - Red - Orange
2 - Green - Green
3 - Blue - Blue
4 - No Connection
5 - Ground - No Connection
6 - Ground - Orange/White
7 - Ground - Green/White
8 - Ground - Blue/White
9 - No Connection
10 - Ground - No Connection
11 - No Connect
12 - DDC DAT - No Connection
13 - Horizontal Synchronization - Brown
14 - Vertical Synchronization - Brown White
15 - DDC Clock - No Connection
HiTech is offline
Old 15th December 2006, 05:55 PM   #12
HiTech, you mention 'good soldering and cable prep skills', however this guy wants to 'weld' it, as he mentions in his first post.
House0Fwax is offline
Old 15th December 2006, 06:41 PM   #13
Strange, first he ask for p1 to rca, now he changed and ask for vga to tv. . . does he really know what he's looking for?
'Intellectuals solve problems. . . Geniuses prevent them.' . . . Albert Einstein
fingaz is offline
Old 15th December 2006, 07:05 PM   #14
He sees with his ears and hears with his eyes. Stand away if he burps.
Old 15th December 2006, 08:44 PM   #15
Yeah, I do see where he mentions about welding it. I gather that next he'll ask for a circuit that allows him to perform low-current welding of hook-up wire! I can help him there as well by having him make use of a rewound MOT.
HiTech is offline
plug, rcastereo, stereo
Stereo Guitar Cabinet Switcher GtarPlaya11 Electronic Projects Design/Ideas/Reviews 51 23rd December 2006 06:55 PM
Fm transmitter fit for a stereo encoder Gideonstk General Electronics Chat 2 28th October 2006 12:57 AM
how to controll volume in a 1W stereo amplifier electronito Electronic Projects Design/Ideas/Reviews 7 23rd October 2006 05:30 AM
Stereo Mute timer? Swifty Electronic Projects Design/Ideas/Reviews 2 23rd December 2003 09:08 PM
Getting stereo from two MC34119 ICs kevinkirkp General Electronics Chat 6 31st January 2003 06:37 PM
