| Dear Friends, I have a problem regarding battery eliminator at output stage. When I connect my audio amp with it, the voltage is getting zero at input stage of voltage of amp and there is no sound. All though audio amp is working good with other eliminator. But when I check the output voltage of eliminator it shows me right voltage like 8v. As I am giving you my component details as follows: Transformer = 12-0-12 Step Down Centre Tap Diode = IN 4007 (2 pieces for bridge) Capacitor = 4700uf 50v (1 piece) Resistance = 100K/3W POT(1 piece) Max Voltage = 17v Now do you solve my problem if you can ! Thank you ! | |
| What's the 100K pot for?. You also need four diodes for a bridge, you have two which could make a fullwave rectifier in conjunction with your centre tapped transformer. | |
| I assume you are trying to use the 100k pot in place of an actual voltage regulator? Not only would that do an extremely poor job of regulating the voltage, you also end up with a very high-impedance source which is probably a terrible choice for powering an amplifier.
__________________ EEgeek.net | |
| Thank you Nigel Goodwin & Evandue ! 100K POT means Potentiometer ! Please tell me how to reduce high impedence source ! With this eliminator I want to run mp3 player, FM Receiver.etc. Actually I don't want to use actual voltage regulator instead I like to use 100k pot in this regard. Please give me some light in this regard ! | |
You NEED a regulator!. | ||
| Adjust the resistance of the pot to half so it is 50k ohms. Then the max load current when its output voltage is 8V is only (17V-8V)/50k= 0.18mA. Nearly nothing.
__________________ EEgeek.net | ||
| I am forced to agree You could reduce the impedance by using several potentiometers in parallel. A stereo potentiometer would reduce the impedance by half, but it would still be useless.
__________________ Seize the time, and seize it now! | |
| constant voltage, constant current Lead Acid Battery Charger | Erwin_Macaraig | Micro Controllers | 1 | 4th October 2008 01:26 AM |
| primitive early design for battery charging | faomari | General Electronics Chat | 3 | 2nd May 2006 04:22 PM |
| Replacing a Battery | DirtyLude | Electronic Projects Design/Ideas/Reviews | 5 | 13th July 2005 01:55 PM |
| Battery indicator consuming batteries | 2camjohn | General Electronics Chat | 3 | 18th February 2005 07:00 PM |
| Connect Battery and PSU at same time...? | grrr_arrghh | General Electronics Chat | 3 | 10th July 2004 12:20 AM |
