I need this circuit to close a relay to stop a stop watch. Would this be the best route to go? Or does anyone know of a better way?
I am using an IR sensor to do the job now. Its kind of difficult to set it up outdoors. The laser would make set up easier. Cost is also a concern if I end up needing a large quantity. http://home.cogeco.ca/~rpaisley4/ATLaserDetctor.GIF |
Without looking at the circuit in too much detail or checking the components.....A relay could be made to work with this and it might be the easiest way to go, depending on how your stopwatch works.
Using a 12VDC relay, connect the positive terminal of the coil to +12V and the negative terminal to the output of the comparator. Then, rather than the led illuminating as the train goes by, the relay will switch. That is what you want, right? |
I know the Cds works because I have used them to remotely control one of my digital cameras. |
Thanks for the reply about the relay. I'm going to give it a try.
This schematic is for a model railroad but I am using it in a different application. The stop watch just needs a closing switch to stop it, so a relay will be fine. I do need the laser because I intend to use it outdoors and the IR sensor I am using is difficult to set up. The visible laser would be bright enough to direct at the "target" (phototransistor), and work, as long as it closes the relay when the beam is broken. |
Len |
I found a much simpler way to do this usin a photo transistor and a transistor to energize the realy. It works here on the bench. Hope to try it in real time this weekend.
Tried it today outside and I am now faced with the sun and all of its output that gets into my photo transistor! Any suggestions? I am going to try mounting the PT in a length of tubing as a type of filter.
This is how remote controls for TVs etc. work. They modulate the signal at either 36 kHz or 40 kHz. You can buy ICs for IR receivers that do the demodulation. For an example of a receiver, see www.jaycar.com.au and search for catalogue number ZD-1952. I don't know if there are transmitters in an IC, so you may have to modulate an IR LED, see cat numbers ZD-1945 and ZD-1946 at the same site.
Len |
I guess I have some learning to do, thanks for the help.
I found antother thread that says the modulation would have to be "pulsed" to avoid being mistaken for interference. How would I do that? Could this be done with a 555 or another IC?
A 555 driving an IR LED is one way it could be done. If necessary, you could mount them in tubes and even use lens to form the light into a beam.
Len |
or just grab an old remote for some gizmo you don't use anymore (ive got lots of vcr remotes (but where did my tapes go?))
the receiver doesn't need to decode what the remote is sending, only that it is transmitting the modulated signal.
If you don't have a planet, what good are gold bars? want to contact me directly? gmail gordonthree check out my project website: http://projects.dimension-x.net Favorite numbers: 09 F9 11 02 9D 74 E3 5B D8 41 56 C5 63 56 88 C0 |
| Modify keyboard | xkrja | Electronic Projects Design/Ideas/Reviews | 4 | 19th September 2006 06:30 AM |
| How to modify this circuit? | erique82 | General Electronics Chat | 11 | 21st January 2006 04:59 AM |
| how to modify a commutator motor to make a generator ?? | williB | General Electronics Chat | 6 | 16th December 2004 02:08 AM |
| Modify the phone protector - OPTOCOUPLER | CyberAle | Electronic Projects Design/Ideas/Reviews | 12 | 6th June 2004 10:53 PM |
| help-' modify a fishfinder to make it remote from sensor' | aahaskins | Electronic Projects Design/Ideas/Reviews | 0 | 8th February 2003 04:01 PM |
