| Hello Dudes!!! Need your help in writing a code that performs the following ( assembly or picbasic it does not matter) I have no problem in using any of the following PIC16F84, F877 , F73 What i need is produce a 1 V for 20 seconds and then produces 2 V for 30 seconds of course we must play with the hardware part too. What are your suggestions??? | |
| The quick and easy way to get an analog voltage out of a micro controller is to use PWM. If you turn a pin on and off 1000 times a second and vary the duty cycle the average voltage is going to be equivilant to the duty cycle (on time) So if your PWM signal is on 50% of the time the voltage should be approximatly 2.5 volts (if you're running your pic at 5 volts) But that's average voltage. In order to turn that into an actual analog signal you need to use a resistor in series with the load and a capacitor shorted to ground. This will let the low frequency (signal) through and shunt the higher frequency (PWM frequency) to ground. There is ripple in this output voltage though so it would help if you told us what this 1 or 2 volt signal was going to do.
| Thanks a lot Sceadwian Appreciated Can you provide me with a sample code if possible or any doc?? | |
| There is more than enough available examples of how to use a PIC's PWM output as a digital to analog converter out there, a simple google search will keep your reading for hours. You simply set a PWM output at the highest possible frequency that will still give it an 8 bit wide duty cycle. Any basic tutorial on a PIC's PWM output abilities will teach you all you need to know. Also look up "Low pass filter" in wikipedia, The most basic form of it is as I described above, a resistor in series with the output and a capacitor shorted to signal ground. But it depends on how fast you need your voltage to change. You will still always have some ripple (related to the PWM frequency) on the output, but the higher the frequency you use for PWM the easier it is to filter out, especially if you only need the signal to change slowly.
| Thanks again | |
| You can also use the comparator reference pin on the 16F628 mcu to get voltages like 0.8, 1.5,2 etc. | |
| The cut off frequency of the LPF should be the same as the PWM frequency or slightly more than it?
__________________ Superman returns.. | |
| The cutoff frequency should match the highest frequency component of the signal you're trying to create. The lower the cutoff frequency compared to the PWM frequency the less ripple.
| Timing Circuit with Relay | Coded_Bananas | Electronic Projects Design/Ideas/Reviews | 6 | 6th October 2006 08:28 AM |
| Timing Diagram and waveform viewer available for PIC? | janetsmith2000@yahoo.com | Micro Controllers | 7 | 12th August 2005 02:17 AM |
| Where to buy PICs in the UK?? | 2camjohn | Micro Controllers | 1 | 7th March 2005 07:01 PM |
| PIC Programmer with 18F PICs | Timmymna | Micro Controllers | 5 | 22nd October 2004 01:44 PM |
| I am interested in PiCs but dont know much about them | cubdh23 | Micro Controllers | 2 | 10th July 2004 08:07 AM |
