Old 8th December 2006, 11:29 PM   (permalink)
Default Flux? (Leds)
What does "Flux" refer to in leds? As in "Piranha SuperFlux" or "High Flux".
I've been nosing around the net for over an hour looking for a good led to use for my home brew traffic advisor, but so far all I can say is there are way too many to choose from
Andy1845c is offline   Reply With Quote
Old 9th December 2006, 12:12 AM   (permalink)
The light output?
It sounds like marketing hype to me.
Screen name: Aloone_Jonez
Hero999 is online now   Reply With Quote
Old 9th December 2006, 01:07 AM   (permalink)
Flux is a buzz word, it means absolutly nothing. Just pick an LED with a high MCD rateing, contrary to previous statement's MCD's are generally representative of the brightness of an LED, although position and distance do matter in the MCD measurement which can vary from company to company. Considering the competion out there for LED's if you have a list of LED's from a single company the highest MCD rateing is going to be compareable to the true brightness of a top of the line brightness LED from another company. The brightness measurement standard within a company should be the same for it's entire product line as long as it's not disreputable.
straight answer, har har."
Old 9th December 2006, 07:34 AM   (permalink)
The flux doesn't mean a thing, just marketting hype.
LED's light output is expressed in MCD or mili candela.
The higher the number the more light output.
Bear in mind that a very narrow beam may have relatively high light output within 6°to 15° of the centre, so check on the data sheet for the viewing angle details of the LED.
RODALCO is offline   Reply With Quote
Old 9th December 2006, 10:46 AM   (permalink)
You can have flux in solder or lines of magnetic flux, but light flux? I agree this certainly is marketing hype.
Old 9th December 2006, 11:41 AM   (permalink)
Flux is a buzzword? I don't think so. Check out the wikipedia article on the candela, the unit of luminous intensity.
http://en.wikipedia.org/wiki/Candela
Notice in the table the definition of a lumen, the unit of "luminous flux". I would also recommend the article on flux which is some quantity that flows through a unit area per unit time.
http://en.wikipedia.org/wiki/Flux
Just because a word is used in a product name does not make the word part of the hype. If you're going to answer questions here, those answers should have some basis in fact and avoid ignorant ramblings.
Papabravo is offline   Reply With Quote
Old 9th December 2006, 12:22 PM   (permalink)
Does Wikipedia mention "flux capacitor"?
Old 9th December 2006, 03:48 PM   (permalink)
PapaBravo, flux is just a buzzword in the usage of (SuperFlux) If you look the word up in the dictionary in the case of electronics or physics it would be a word used to describe power, which is why it's mentioned in the wikipedia entry. It's just a 'fancy' way of saying 'High Power' Superflux just sounds cooler, so it is 100% buzz.
Old 9th December 2006, 03:57 PM   (permalink)
Funnily enough it does.
http://en.wikipedia.org/wiki/Flux#See_also
Old 9th December 2006, 09:11 PM   (permalink)
It does and it tells the story of its occurrence in the series of Back to the Future movies. The article makes it pretty clear that is a fictional concept.
Old 9th December 2006, 09:16 PM   (permalink)
Hype or not I guess you're entitled to your opinion.
Old 9th December 2006, 10:10 PM   (permalink)
It certainly seems like sales hype to me. . .
And isn't it annoying that different LED manufacturers use different methods to measure the luminous intensity of their LED's? We have a standard way of measuring voltage, capacitors, resisitors, transistor gain etc. etc. Can you imagine if we didn't? (well, it's 150k ohm if you solder it on a tuesday before 3pm, after that, it goes down to 120k) Well, maybe not THAT bad, but you get the idea. . .
Just think there should be a standard way of measuring. . .
Oh well, that's my moaning done for the day
'Intellectuals solve problems. . . Geniuses prevent them.' . . . Albert Einstein
fingaz is offline   Reply With Quote
Old 9th December 2006, 10:24 PM   (permalink)
People in the RF community have been saying the same thing for years. It's not that simple. When you get into propagation effects, like RF radiation or light emiting, the entire nature of the beast changes. It's like going from 9 volts to 9kv's The same rules don't apply. Different materials act in differnet manners under different cirucmstances, and there is no way to properly predict a users circumstances under anything except the user putting the device to work and debugging it. Everyone wants their device to be the best, of course they're going to place their device in the best light it can be placed in.
Old 9th December 2006, 11:32 PM   (permalink)
I think it's more to do with the manufacturers wanting to make their product look the best. They'll inven a new way of measuring intensity and a more complex way of explaining things to confuse people it's better.
Old 10th December 2006, 12:05 AM   (permalink)
If you wish to measure something there is only one way of doing it. Power vs distance. To achieve a greater measure of power over a distance, you need to focus your output. LED's achieve this by their output methods.
Super Flux LED's amazing !!! udi_hakim General Electronics Chat 10 17th February 2007 05:04 PM
LEDs from the Far East. ThermalRunaway General Electronics Chat 12 15th August 2006 01:37 AM
Long-life circuit for LEDs and a clock dabuttery Electronic Projects Design/Ideas/Reviews 4 22nd February 2006 03:16 PM
Question about LEDs and resistors. tribaloverkill Electronic Projects Design/Ideas/Reviews 5 1st November 2004 04:54 AM
Flux! - It's not a dirty word. Squintz General Electronics Chat 13 10th November 2003 08:58 AM
