Old 8th December 2006, 04:14 PM   (permalink)
Default pH transmitter electrical interference problem
I use two pH transmitters as inputs to my PLC system for controlling pH in two tanks. The two transmitters are two-wire transmitter with automatic temperature compensation. They share one 24VDC power supply. Although they are great when wired to the system alone. But when the other one is wire up to the PLC system, there is serious interference between the two transmitters: neither gives reasonable reading for standard solutions.
Please help me on removing the interference.
Thanks a lot.
sparkinite is offline   Reply With Quote
Old 8th December 2006, 07:54 PM   (permalink)
So I presume by two wire you mean 4-20 mA current loop type. PLease confirm. These should be OK together if they are wired correctly. Can you post a sketch showing how you've connected them up? It would also be helpful to know the model of PLC that you are hooking up to and if you could tell us whether you have external load resistors or they are built into the PLC. Oh, and while we are at it, what is the model of transmitter you are using?
RadioRon
RadioRon is offline   Reply With Quote
Old 8th December 2006, 11:08 PM   (permalink)
probably 4-20mA. Show a diagram, pay particular attention on how the two transmitters are grounded with respect to the loop and each other.
"Everything that is done in the world is done by hope." -Martin Luther
"There are two ways to live your life. One is as though nothing is a miracle. The other is as though everything is a miracle."-Albert Einstein
Analog is offline   Reply With Quote
Old 9th December 2006, 01:21 AM   (permalink)
You're not trying to connect two sensors to a single input are you?
straight answer, har har."
FM Transmitter, ipod, ipod charger interference? adamthole General Electronics Chat 1 20th December 2005 12:53 AM
FM Transmitter: Where's the problem? DigiTan General Electronics Chat 22 30th March 2005 11:13 AM
Transmitter and Reciever Problem redhot23elmo Electronic Projects Design/Ideas/Reviews 2 12th June 2004 06:38 AM
3V IR transmitter problem! brodin General Electronics Chat 27 29th April 2004 10:34 PM
FM Transmitter problem Zarniwoop Electronic Projects Design/Ideas/Reviews 2 19th October 2003 09:31 AM
