Old 8th December 2006, 01:12 PM   (permalink)
Angry How can I fix my flash drive?
the problem is "Write protection error"
My flash drive was not in a write protect mode when I was copying files in it, suddenly error appears. Some files were already written but i was not able to finish. I tried switching the write protect switch back and forth nothing happens, it is still the same. So I opened the flash drive physically and disconnected the write protect switch and I put some jumper on where it is connected, still nothing happens. By the way the circuit is very small and Im having difficulty for it too.
Could it be the IC is damage?
andales is offline
Old 8th December 2006, 01:14 PM   (permalink)
Have you tried reformatting it?.
Nigel Goodwin is online now
Old 8th December 2006, 01:20 PM   (permalink)
The error says "write protection error"
Yes, I already did even before opening the flash drive and disconnected some the switch part, error still the same. can't format it. computer says remove write protection.
andales is offline
Old 8th December 2006, 01:25 PM   (permalink)
Is it that same file each time it says it? Try coping another group of files to make sure the OS it not wacky. Also, maybe re-install the drivers (USB drivers) maybe they are corrupt. Otherwise maybe a bad memory chip on the board. They are cheap to replace now.
mramos1 is offline
Old 8th December 2006, 01:36 PM   (permalink)
Are you sure that shorting out the write protection jumper doesn't enable write protection?
straight answer, har har."
Sceadwian is offline
Old 8th December 2006, 01:45 PM   (permalink)
mramos1
All or any files could not be written on the flash drive, I even tried plugging the flash drive to other computers thinking it is my usb port that have a problem. Still the same. Any file could not be written on the flash drive.
What board are you talking about? PC or flash drive?
If flash drive, how can I connect the chip when the circuit is very small?
andales is offline
Old 8th December 2006, 01:47 PM   (permalink)
Sceadwian
I was thinking it was the switch that was broken. some lose connection might have occured thats why I shorted the connection where it is supposed to disable the write protecion.
The logic of switch is "open and close". Closed switch could allow current to flow, if open you know what i mean.
I actually left it hanging before i short circuited it when it tested it if it works. Shorted or not, unable to write.
andales is offline
Old 8th December 2006, 05:03 PM   (permalink)
Sounds like time for a new flash drive. BTW: On mine it is a short to write protect it.
mramos1 is offline
Disposiable camera flash modification HarveyH42 Electronic Projects Design/Ideas/Reviews 9 5th April 2006 05:24 PM
How to reset SCR used for triggering camera flash shootfirst Electronic Projects Design/Ideas/Reviews 20 28th September 2005 09:40 PM
electric car drive franklin2 Electronic Projects Design/Ideas/Reviews 8 18th October 2004 03:30 PM
electronic switch to enable a camera to fire a flashgun tony ellis Electronic Projects Design/Ideas/Reviews 10 30th September 2004 11:19 AM
flash based PICs samcheetah Micro Controllers 11 7th July 2004 06:41 PM
