| Notices |
| LEDs will consume more current when put in parallel. In series, the current will be equal to a single LED's current while the voltage when measured with reference to ground will be different for each LED. Be sure to take care of the series resistor. Aily ---- MoM!!!! My transistor is suffering from fever. It heats up!! | |
| aily brother do u clarify me the switch system (combination switch's off on HL connections point to point) of the CT90 s wiring diagram. pleaaaaase... dr do ask for resistor in every LED?? do u mean that LED consume more current in parallal connection. if so why maximum lowvolt Led flash light use LED in parallal connection, because it reduce battery life faster. confused??!!!
__________________ 'if u cant beat him then join him' I always say... Last edited by mamun2a; 7th December 2006 at 10:53 AM. | |
Just because the total current draw is lower when they're run in series, DOESN'T mean the total power is different. power is voltage times current (P=VI) so running them in series you get high V but low I, and in parallel you get low V but high I. The total power would then be the same either way.
__________________ EEgeek.net | ||
| Power depends upon if you run a single LED wirh correct resistor from 12 Volts, or 3 LED's in series from 12 Volts with a series R. 1. If you put 3 single LED's drawing 20 mA each, with their own resistor on the 12 Volts supply the power usage will be higher. 2. Put the 3 LED's in series, drawing 20 mA with a single dropping resistor, usage will be lower. In the first case each resistor will have to dissipate about 8 to 9 volts at 20 mA in heat. (taken 3½ to 4 volts per white LED) In the second case the LED's consume about 10.5 volts and the series resistor only has to dissipate about 1.5 - 2 volts at 20 mA's.
__________________ There are more ways to get to Rome. Electricity, Electric clocks, Meters and Trains are great. | |
| Put the LEDs in series for optimum effieiency and use an appropriet value series resistor.
Assuming you have control over what supply voltage you want, it doesn't really matter whether you use series or parallel in terms of power usage. If you are stuck with a certain voltage, you quite simply put as many LEDs as you can in series such that the sum of forward voltages is lower than your supply voltage, and then put several of these series combinations in parallel if you need more LEDs.
| Interfacing 4000 series CMOS to 74HC series TTL | kd4pbj | General Electronics Chat | 11 | 22nd January 2007 04:52 PM |
| Zener Diode Series # | redart | General Electronics Chat | 3 | 4th May 2006 11:44 PM |
| 40 Series IC. | lord loh. | General Electronics Chat | 2 | 18th February 2006 04:05 AM |
| Basic Charts for series AC circuits | walters | General Electronics Chat | 2 | 23rd June 2005 10:35 AM |
| PIC 18 series in circuit programmer? | wsc | General Electronics Chat | 4 | 13th May 2004 07:36 PM |
