Old 25th November 2006, 05:05 AM   (permalink)
Default solar switch: need help
I am trying to build a solar switch that turns the light on at night and off durring the day.
I am using one transistor that at night the transistor turns on because no current it going to the base and then during the day the light turns off because a current goes to the transistor.
Please look at the attached image to see how I have breadboarded it I hope you will be able to tell me what I am doing wrong.
Thanks in advance
Justin.
mettam is offline
Old 25th November 2006, 05:32 AM   (permalink)
You forgot to attach the schematic with parts values so we know what the circuit is doing.
You forgot to tell us what is the problem. It looks like it works.
Don't you want the solar panel to charge the battery during the day?
audioguru is offline
Old 25th November 2006, 05:49 AM   (permalink)
In your photo, it appears that you have the solar cell leads both plugged into the same terminal and therefore shorted out and doing nothing. It also appears as if you have no current limiting resistor in series with the LED, so I will assume that you are using one of those LEDs with the resistor built-in. This circuit might work if you are using a FET and you apply the solar cell voltage with the right polarity. Can you provide any more info?
Also, I don't recognize that solar panel but I hope it has more than one cell in it, because one cell only gives about 0.5 volts which isn't enough to bias off the FET.
RadioRon
RadioRon is offline
Old 25th November 2006, 07:36 AM   (permalink)
I don't have schematic drawing software.
The parts are just a LED a Transistor (what kind I don't know) and a 2V 200mA solar cell.
Yes I will have the panels charge the batteries during the day.
The problem is that when I put light on the Solar Panel the LED stays on and it should go off.
I thought maybe the solar panel didn't produce enough power even in a lit room to effect the transistor but when I connected a 4 Volt battery to it it still didnt work.
I drew my inspiration from this site. http://www.allaboutcircuits.com/vol_3/chpt_4/2.html
mettam is offline
Old 25th November 2006, 07:46 AM   (permalink)
No the LED doesn't have a current limiting resistor built in.
I have pluged the solar cell terminals into the Transistor in a number of different configurations the photo does show both the + - going into the base but I have had the + to base and - to emitter,
I didn't see any need to put a resistor in series since the load can handle the source without heating up.
Sorry if my aproach is ridiculous as I am a newbie to electronics, its hard to teach myself electronics with out any one to show me stuff.
mettam is offline
Old 25th November 2006, 08:28 AM   (permalink)
I use either Powerpoint to draw circuits or simply draw it by hand and scan. Do a search of my posts and you will see examples.
The circuits shown in http://www.allaboutcircuits.com/vol_3/chpt_4/2.html are fairly basic and need to be used with caution.
You need resistors in series with both the base and collector in order to prevent the possibility of damage to either the transistor or the LED.
Len
ljcox is offline
Old 25th November 2006, 02:52 PM   (permalink)
Your LED stays on?
Then the transistor might be destroyed because your circuit doesn't have a resistor in series with the base to limit the current and does't have a resistor in series with the LED to limit its current, or the transistor is the wrong kind. How do you know which pin is which on the transistor? Maybe the pins on the transistor are in the wrong place, so it is acting like a diode.
Do you see that your solar cell has both of its wires together so is shorted?
Your battery looks like 3 AA Ni-Cad or NI-MH rechargable cells that are in series making 3.75V. It cannot be charged from a solar cell that has only 2V.
I use Microsoft Paint program to make schematics by making a few straight lines with the Shift key down then using copy and paste to get parts of other schematics or datasheets.
Old 25th November 2006, 04:40 PM   (permalink)
If add a cap. in parallel to and a diode in series with Battery, is it work?
mm0935 is offline
Old 25th November 2006, 04:56 PM   (permalink)
Adding a capacitor and diode won't fix the problem of the base and collector of the transistor don't have current-limiting resistors, the solar panel is shorted or the transistor is connected backwards.
Old 25th November 2006, 05:02 PM   (permalink)
mettam, you need to re-read Radio Ron's post above.
Sceadwian is offline
Old 25th November 2006, 05:52 PM   (permalink)
sorry! I was side trace.
yes, The terminals of solor cell seems connected in short circuit.
mm0935 is offline
Touch Sensitive Switch (Take 2) MonkeyMera Electronic Projects Design/Ideas/Reviews 7 2nd October 2007 11:05 PM
PIC Switch Management Techniques Mike, K8LH Micro Controllers 2 28th September 2006 01:33 PM
Solar Cell as Switch? rrlsmontana Electronic Projects Design/Ideas/Reviews 8 11th April 2004 10:17 AM
Advice and information connecting Hex coded rotary switch Barry Micro Controllers 2 6th March 2004 10:38 AM
How to configure this On/Off Switch with Bicolor LED?HELP ME Stimulation Electronic Projects Design/Ideas/Reviews 10 23rd April 2003 05:55 AM
