| I know you can drive an LED with just a resistor hooked up directly to the source, but which way would be more efficient in driving a LED; PMW (ie, 555 timer) or a Constant Current Source (A Transistor; mosfet, regulator..etc) when it comes to saving battery life while getting the most brightness? Last edited by Overclocked; 23rd November 2006 at 04:31 PM. | |
| pulsed uses less power than continuous wave, if by brightness, you mean apparent brightness, as it applies to the human vision model ... then a 50% PWM with a freq of 150 to 1000 hz would do nicely. ps, you still need the resistor! btw, what do you mean by efficient? if your goal is to drive a single LED from a fixed voltage source, the most efficient thing to do is match the led's forward voltage to that of the source ... in other words, you can run two red leds off a 5v rail for the same 'energy cost' as it takes to run 1 red led off the same 5v rail, you're just dropping 1v in a resistor instead of 3v. if matching Vf to Vcc is not possible, then a switching regulator will be your most efficient means of driving the LED, for example, high power LED taillights (think 1.5 to 3a), using a resistor (or worse, a linear reg) you end up wasting tens of watts of power, using a switcher you end up wasting only a few. linear regulators (pass transistors and the like) are the worst in terms of efficiency, much worse than a resistor, however, they're also very flexible, so that is a trade-off to be considered.
__________________ If you don't have a planet, what good are gold bars? want to contact me directly? gmail gordonthree check out my project website: http://projects.dimension-x.net Favorite numbers: 09 F9 11 02 9D 74 E3 5B D8 41 56 C5 63 56 88 C0 | |
I mean bright as in if you Ran a LED from 12V with a 180 to 270 Ohm resistor (blue, white..etc LEDs). Bright as in you can read from a single LED. Ive read (somewhere..) that driving LEDs with Resistors is somewhat innefficient because of the resistor (maybe it was hackaday or Digg..). But I think you hit My question..Now all I have to do is find the circuit. I have a bunch of Inductors from RadioShack that I have to measure. | ||
| I built a 555 Timer Circuit that operates at 32kHz, along with a Transistor on the Output. On the base of the transistor is a 1k Ohm resistor, on the Collector is a 180 Ohm resistor, and on the emitter are 4 LEDs in parallel with each other. I measure 25 mA Total Current with the battery being at 8 Volts. The Current Going through the Collector is 17.80mA. Each LED Is getting 2.78V. These are White LEDs (Info here:http://www.lsdiodes.com/shop/index.p...products_id=22) Now for the calcs, Pin= 8V*25mA = .2W, But heres where Im confused. If I do 17.8mA * 2.78V I get 0.04 W. Did I use the right Voltage? Now to Calc % Efficiency (Pout/Pin *100) So, 0.04/2= 20%!!! How can that be? 20% Efficiency? Im questioning by Numbers, Theres no way that can be right. (Maybe it isnt, Since Its a pulsed Signal..) Btw, I measure 120mA with just the LEDs and resistors, So I Guess its an Improvement. | |
| The LEDs are only 2.78V but the battery is 8V so only 35% of the battery voltage is used for the LEDs and the rest is wasted as heat. Additional power is wasted because the 555 isn't a low power Cmos 555, and the 1k resistor also wastes some power. Instead if 2 LEDs are in series and 2 groups of them are in parallel (and their resistor values reduced so they have the same current as before) then the efficiency is doubled and the wasted battery power is halved. The transistor works better as a common-emitter switch instead of an emitter-follower as you described. If you pulse it then it looks dimmer. Your vision isn't a peak and hold circuit like some people think. Brightness is sensed as the average power in a pulsed light. That is how a PWM light dimmer works.
In a common emitter circuit isnt the signal on the collector Inverted? I guess it wouldnt matter if it was inverted or not. | ||
| | (permalink) | |||
__________________ Uncle $crooge | ||||
| Intresting- All this time I thought I was running a Regular 555 Timer (NE555...etc), But In fact, I am using GLC555 Timer. In the data sheet it claims it uses 100uA to 300uA. So In Fact It is a low power 555 Timer, But the large amount of current is probably due to the RRC Network. Now it makes me wonder, Since I am getting appr. 1/2 the brightness I would Usually, Is it worth driving these with a pulse? Cant I just save power by using a bigger Resistor? My Math Proves me wrong. 180 Ohms (Which is the resistor I use from voltages >5V) *2=360Ohms. Since a White Led Takes 3.3V, and VCC=9V, Vr=5.7V. since R=360Ohms, 5.7/360 = 15mA. Now since (For experimental Purpose...) Im using 4 LEDs, 15mA* (15mA Per branch) 4 = 60mA, Half of the 120mA I was using before with 180Ohm resistors. So, P=IE, 9V*60mA= =.54 W. So, In this case I still Come out better using a 555 Timer. Granted, It takes up Less current, But at the cost Of Brightness and (possibly) efficiency. But Is there really a loss of efficiency? If 5.7V is Accross the resistor, and theres a current of 15mA then, Pr=0.0855W * 4 =.342W. So then Each LED is dissipating .198W Hmm, Then It seems I may have proved something I already knew. So With that said, Which is more efficient, Boost-Buck or PMW? | |
| leds in series = more efficient ... dropping more than 2 or 3 volt across a resistor is wasting that energy by heating the resistor when it could be lighting an LED a switchmode supply is only gonna make things a LOT more complicated for very little return. all an smps is going to do is squeeze more power out of the battery before the leds go dark. check out the joule-thief for this concept.
| You can't calculate how much current is in the LEDs unless you measure the voltage drop across the current-limiting resistor. Your transistor isn't a common-emitter switch so as an emitter-follower it has about 0.7V or more wasted across it. Some LEDs are more efficient at higher current but other LEDs are less efficient. Check the datasheet for your LEDs. If the efficiency of your LEDs stays the same at any current then if you pulse them with a 50% duty cycle to save power then they will look half as bright.
| Ive been brainstorming a bit on how I could reduce current in this thing. 1) Move LED from Emitter to Collector 2) Reduce ON time as Much as Possible (10% Duty Cycle-100Khz Maybe?) 3) Possibly Remove the Transistor. I think a 555 Can supply up to 200mA. Im consuming a fraction of that. Another Idea I have- 1) Use CMOS or TTL (Low power) Gates to make a Simple Oscillator. Theoretically, It SHOULD consume very low power. 2) Instead of LEDs Use CCLs. They use Inverters So there would be no real reason to power them with a 555 Timer. DC would work Fine. I have to seem how much mA they consume though. The only problem is they are bit more expensive that LEDs (Not Much though..) | |
| You don't gain anything if you power an LED from an oscillator. The duty-cycle of the on-off time determines the brightness. The same amount of power is used if it is the same brightness as with a continuous DC current. The only thing an oscillator provides is PWM to dim the brightness efficiently. If you use a very low power Cmos oscillator circuit then the few mA of a 555 won't be wasted, but the LED still needs current pulses of maybe 60mA. 60mA is not low power unless you use a car battery. You need to use a battery that keeps its voltage up as it runs down. Then the voltage across the current-limiting resistor isn't high so it doesn't waste too much power.
| You don't need to boost the voltage if you use a cell from the "lappy". It is probably Li-Ion and is about 3.6V so it is just right for powering 3.3V white LEDs through resistors. The Li-Ion cell will be 4.2V just after charging so the current-limiting resistor for each LED is 4.2V-3.3V/30mA= 30 ohms. When the Li-Ion cell's voltage quickly drops to 3.6V then the current in each LED will be 3.6V-3.3V/30 ohms= 10mA. Don't connect LEDs in parallel. Each one has a slightly different voltage so their currents will be different and maybe the one with the lowest voltage will hog all the current and burn out. Then the next will burn out, then the next. Use a separate current-limiting resistor for each LED. You will need a circuit to shut off the power from a Li-Ion cell when its voltage gets too low, or the cell will be ruined. I think the minimum voltage is about 3.0V. Even with only 3.0V, a 3.3V LED will make some light. Be very careful when you charge Li-Ion cells. If they get overcharged then they catch on fire and make a very hot, white flame like magnesium.
| Stepper Motor Driving Using PIC16F74 | t_anjan | Electronic Projects Design/Ideas/Reviews | 0 | 31st January 2006 07:14 PM |
| Driving reed switches. | Optikon | General Electronics Chat | 12 | 14th October 2005 11:23 PM |
| Driving LED lighting via a PC soundcard | roborg | General Electronics Chat | 7 | 7th November 2004 12:31 AM |
| Driving +12 via +5 TTL logic and a PNP transistor | gduprey | General Electronics Chat | 4 | 6th October 2003 04:15 PM |
| Driving Luxeon LEDS | archangel2 | General Electronics Chat | 13 | 19th August 2003 05:31 AM |
