| If i had a wire with a flow of 6.3x10^36 electrons flowing in a wire per second, what would the current be? | |
| approximately 1 x 10^18 amps | |
| Wouldn't it be 1161 mA ? Last edited by windozeuser; 14th November 2006 at 12:07 AM. | |
| well 1 Amp of current is 6.25*10^18 electrons flowing at a specific point in a conductor in one sec. Otherwise known as a coulomb of charge. | |
| I thought it was 6.28*10^18 electrons??? maybe I'm wrong??? But you can't end up with a number that low (1161mA) because 6.3*10^36 = 6300000000000000000000000000000000000 and one coulomb is 6.28*10^18 = 6280000000000000000 ^ means "to the power of" look up "exponentiation"
__________________ 'Intellectuals solve problems. . . Geniuses prevent them.' . . . Albert Einstein | |
| 6.3x10^36 electrons / 6.25*10^18 = 1 amp with 1.008*10^18 electrons left for a remainder the 1.008*10^18 electrons will be less than an amp of current, 1.008*10^18/6.25*10^18 = 0.16128 amps hence, 1161 mA Anyone please correct me if I'm wrong 1A = 6.25*10^18 electrons per second A = Q/T | |
| It doesn't work that way. . . 6.3*10^36 = 6,300,000,000,000,000,000,000,000,000,000,000,000 This means 6.3 multiplied by 10 36 times (6.3*10*10*10*10*10 etc. etc. etc.) so you can't just take 18 off the 36. . . and one coulomb is definitely 6.28*10^18 = 6,280,000,000,000,000,000 (see here) http://www.essex1.com/people/speer/elect.html Deviding this 6,280,000,000,000,000,000 By this 6,300,000,000,000,000,000,000,000,000,000,000,000 DOES NOT leave less than one amp. Like I said, you need to look up the meaning of EXPONENTIATION. You can't just take away bits of the equation before you've calculated it! The 'exponent' determines the position of the decimal point, and therefore the final value of the number. eg. 6*10^3 = 6000 = 6 with 3 zero's before the decimal point. You have to calculate the equation in the order in which it is written (except in the case of parantheses, which should be calculated first) so 6.3*10^36 means you must calculate this [6,300,000,000,000,000,000,000,000,000,000,000,000], (before you move on to the next part if the equation) DEVIDED BY 6.28*10^18 [628,000,000,000,000,000] which DOES NOT EQUAL 1 Amp with 1.008*10^18 electrons left for a remainder It does in fact equal 1.0031847^18 AMPS of current [1,003,184,700,000,000,000] APPROXIMATELY
__________________ 'Intellectuals solve problems. . . Geniuses prevent them.' . . . Albert Einstein Last edited by fingaz; 14th November 2006 at 09:50 PM. | |
| Really well... (2.25 x 10^22 electrons) / (6.25 x 10^18 electrons per second) = (2.25 / 6.25) x (10^22 / 10^18) = 3.6 x 10^3 or 3600 | |
| SCRAP MY LAST POST. . . I'VE JUST SEEN WHERE YOUR CALCULATION IS WRONG. . . what you did is 6.3*10^36 / 6.25*10^18 = 1.008^18 This indicates the number of AMPS, NOT the remainder after taking away one amp. You divided the TOTAL NUMBER of electrons by the NUMBER OF ELECTRONS IN ONE AMP, to get the TOTAL NUMBER OF AMPS. Well, enough of that. . . It had me pulling out what bit of hair I got left! Though I still maintain it 6.28*10^18 electrons
| ah well that's one hell of a current | |
and 1 coulomb = approx. 6.24 x10^18 electrons. therefore 6.3x10^36 / 6.24x10^18 = 1.0096x10^18 coulombs/sec or 1.0096 x 10^18 amps | ||
| I'm glad to see you've all done his coursework for him!
| about capacitor..... | jin29_neci | General Electronics Chat | 4 | 23rd August 2005 03:33 PM |
| Battry charge cut & on | Rakesh Sharma | General Electronics Chat | 4 | 2nd January 2005 04:07 AM |
| Charge Amplifiers | newb | Electronic Projects Design/Ideas/Reviews | 1 | 7th May 2004 01:42 PM |
| charge amplifier wat and how? | newb | General Electronics Chat | 0 | 5th May 2004 05:48 PM |
| can capacitor store charge.? please help. | Faiyaz | General Electronics Chat | 3 | 19th October 2003 06:38 AM |
