+ Reply to Thread
Page 2 of 2
First 1 2
Results 16 to 20 of 20
Thread: Simple question: What resistor to buy?
  1. #16
    Join Date
    Mar 2004
    Location
    Canada, of course!
    Posts
    19,870
    It is wasteful to power individual 1.7V LEDs from a 9V battery because 7V is not used for the LEDs. Connect 2 LEDs in series and in series with a 220 ohm resistor for 25.5mA with a new 9V battery and 11.8mA when the battery voltage has dropped to 6V. Make 5 groups like this.
    The LEDs probably have a "typical" voltage of 1.7V but it could be 2V max. Then 3 in series wouldn't light when the battery voltage drops to 6V and they would be very dim for most of the time.
  2. #17
    ajd344 Newbie
    Join Date
    Nov 2006
    Posts
    7
    OK, thanks for your help! Actually, my friend's father is an electrical engineer and I went over to his house and he helped me out with the plans. It makes sense now! Thanks a lot!
  3. #18
    Richard Principal Bad
    Join Date
    Nov 2006
    Posts
    43
    Quote Originally Posted by FusionITR
    You wouldnt want to do away with the resistor because you will need something to limit the current. 0.1V different in the diode group could mean an extra 100mA of current going through it (diode voltage-current relationships are not linear).
    you dont need any resistor if you put say 10 1.7 Volt LED in series and run it off 17 Volts you would not have to limit the cureent,
    it would have to be the best way to stop power wasteing if you had the right power for the LED.
  4. #19
    Join Date
    Mar 2004
    Location
    Canada, of course!
    Posts
    19,870
    Quote Originally Posted by Richard Principal
    you dont need any resistor if you put say 10 1.7 Volt LED in series and run it off 17 Volts you would not have to limit the current.
    The voltage rating for the LEDs "might" be 1.7V, but it isn't guaranteed. They might actually be 1.6V then without a current-limiting resistor their current would be way too high and they will blow up. They could actually be 1.8V or even 2.0V then they won't light unless some extra voltage is provided.
    He doesn't have 17V. He is thinking of using two 9V batteries, that produce about 19V when new and drop to 12V when finished.
  5. #20
    em2006 Newbie
    Join Date
    Nov 2006
    Location
    Bucharest, Romania
    Posts
    93
    Using a constant current generator is a good solution.
+ Reply to Thread
Page 2 of 2
First 1 2
  1. Simple question on touch sensitive switches.
    By swedishlf in forum General Electronics Chat
    Latest: 20th December 2009, 04:28 AM
  2. Simple Question
    By WonDer7002 in forum General Electronics Chat
    Latest: 1st November 2006, 09:21 PM
  3. Simple (?) redundant power question
    By q9 in forum General Electronics Chat
    Latest: 28th October 2005, 01:33 PM
  4. (Hopefully) simple question.
    By cceto1 in forum General Electronics Chat
    Latest: 13th July 2004, 06:58 PM
  5. Simple Question
    By duckfoo in forum General Electronics Chat
    Latest: 21st September 2003, 04:03 AM
Tags for this Thread
