Old 5th November 2006, 09:18 AM   (permalink)
Default some questions about voltage regulator
usually use voltage regulator to step down voltage, the pin 1 (Vin) and pin 2 (Vout) should place a capacitor,y should place it??
then how i know wat value capacitor i should to use??
wat effect of the capacity higher or lower for a voltage regulator??
miaomiaooh is offline
Old 5th November 2006, 12:19 PM   (permalink)
If you are talking about a 3-terminal regulator, please include a part number. For these, check the data sheet for appropriate values. The caps are needed for stability purposes.
"Everything that is done in the world is done by hope." -Martin Luther
"There are two ways to live your life. One is as though nothing is a miracle. The other is as though everything is a miracle."-Albert Einstein
Analog is offline
Old 5th November 2006, 02:03 PM   (permalink)
the voltage regulator is 7808, i found some data sheet about the 78xx,pin 1 is place 0.33uF and pin 3 is place 0.1uF.
if i place both 15pF, wat different?
Old 5th November 2006, 05:24 PM   (permalink)
If the datasheet says to use certain capacitors, then why change them to be 22,000 times smaller in value?? 15pF is almost nothing.
audioguru is offline
Old 5th November 2006, 06:00 PM   (permalink)
15pf is too small for a three terminal regulator unless you're using it for phase margin compensation in a more exotic regulator but we don't really know since you haven't posted a schematic!
Screen name: Aloone_Jonez
Hero999 is offline
Old 6th November 2006, 12:39 AM   (permalink)
wat the function of capacitor for voltage regulator??if i dun place it,wat will happen??
Old 6th November 2006, 12:49 AM   (permalink)
Look up the meaning of stability. The regulator's datasheet says they are for stability.
A regulator might oscillate without the recommended capacitors and the datasheet shows the output step response with overshoot and ringing when the output capacitor is too small.
Old 6th November 2006, 05:03 AM   (permalink)
The caps are for stability and they help regulate the output. The response of the regulator is some what slow. For example if you a using the regulator to drive a device that outputs a fast pulsating voltage output the regulator want be able to respond to the fast changing o/p current demand and the output of the regulator also begins pulsating.(Disastorous if you are driving a MCU). The caps works by providing the necessary current till the regulator can respond. So small caps will be ineffective depending on you application. A too large one will increase your start up times.
ShockSL is offline
DC current or voltage regulator, for an analog multimeter steelgod Electronic Projects Design/Ideas/Reviews 4 10th June 2006 09:31 AM
voltage regulator and PIR sensors manz Datasheet/Parts Requests 2 25th December 2005 04:13 AM
How to use Voltage Regulator in MultiSim8? Almazick General Electronics Chat 0 1st August 2005 03:23 AM
ecg 957 voltage regulator spec sheet inkedallusion Datasheet/Parts Requests 1 5th January 2003 07:11 AM
40-120V DC to 5V@120mA Voltage Regulator. gasson Electronic Projects Design/Ideas/Reviews 2 30th October 2002 04:43 PM
