| Hi, I'm using a 1000uF 16V capacitor in my power supply (12V AC rectified). The voltage on the capacitor terminals is 15.5V. I'd like to know if the 16V parameter of my capacitor is a stress value, or if it's a nominal value meaning that my capacitor is safe with voltages less or equal than that. Thanks | |
| If I remember correctly that is the capacitors maximum safe voltage, if exceeded, the capacitor could pop, melt itself, unbond the solder, discharge too much/too little, spike, short, etc. I'd say stay just below the max voltage just to be safe.
__________________ E=MC^18357891237358179238, it\'ll still come out right every time. Try it some time, it\'s all relative to the equation. | |
| personaly id use a 25 or 50 volt cap, since its quite possible to have a surge that would overflow the cap...
__________________ Do no meddel in the affairs of dragons, for you are tasty and go good with ketchup. | |
| Even I use capacitors with atleast 15-25V higher ratings than required. Its is always better to use a higher voltage value capacitor than a lower one.
__________________ "There is no way to peace, peace is the way!" | |
| i have read someplace that the cap rating voltage should be with at least 20% greater than the voltage the cap is used in the circuit. | |
| i read twice, but that seems a good bit too much. :S
__________________ Mike Bradley ate my hamster. | |
| I always try to stay at leist 10 to 15 volts above the circuit voltage level. It will also extend the capacitor's life and the circuit's reliability. | |
| Electrolytic capacitors are 'formed' during manufacture by depositing an anodic film on the aluminium foil that makes up the anode, that will withstand the operating voltage plus (typically) 10%. So you are quite safe to operate them at their specified working voltage. | |
| Hi sbayeta, just my 2 cents worth; if a circuit runs 10-15 volts I use 25 volt caps 16-24 volts I use 35 volt caps 25-40 volts I use 50 volt caps Using a higher voltage rating cap is *always* advisable IMHO. It's cheap insurance :wink: | |
| I have a question along the same lines what about the uF is that just a "safe" working value or would replacing a capacitor with a higher UF be a bad Idea? For exaple I have a 100uF 16V capacitor and was thinking of replacing it with a 150uF 20V. | |
| I did some further research on this and found that in doing repairs, it is not a good idea to change the uF of the capacitors used. So I could go with a 100uF 20V but shouldn't use a 150uF 20V. If anyone has more information on this feel free to say so, as I am just going off what I have read. | |
| Think of it like a resistor. A resistor has a power rating (in wattage) and a resistance rating. You can replace a 300-ohm ¼ watt resistor with a 300-ohm 1-watt resistor. Only difference is that the 1-watt resistor can withstand a higher current/wattage (or heat) level. Having a higher wattage handling capability does not affect the circuit design, other than giving it the ability to handle more heat. However, if you change the resistance value, then you change the current level across the resistor and across the circuit. That will definitely affect the circuit. (In this example, uF rating is equivalent to resistance and wattage is equivalent to voltage – Just an analogy to try to put it in perspective :wink: ) | |
Other than that, electrolytics are used as reservoir or smoothing and you can usually safely exceed the capacity specified. The only time I would add a word of caution is if the capacitor is very large, say, several thousand uF and is used as reservoir straight after a recifier and with no series resistor to limit surges. In that case the rectifier could possibly be damaged by the surge current. As I said before, eleectroytics should be used within their rated (as marked) voltage. Straight after a rectifier the voltage can increase to 1.4 x the applied AC, so it is a point to watch. | ||
| iv always learnt to use atleast double the voltage iv seen these blow | |
| I would absolutely no questions asked use a 25V rated cap. 15.5V and 16V capacitor is a recipe for POP! | |
