I turned the scope on, it made a buzzing sound, a green line appeared briefly on the screen briefly then it stopped working. I've noticed that the internal fuse has blown, now I'm going to replace all the capacitors on the supply, and check the rectifiers too. It's a very old scope, it only goes up to 1MHz and it's all discrete componants but no valves so I suppose it can't be that old. One unusual thing is it doesn't have a flyback, instead it has a multiplier made from eight 450V 4.7µ f capacitors, is this normal? Should I replace them all to? Is there anything else I should check? I'm concerned I may've caused this, when I got the scope out I noticed a piece of dirt had sliped under the screen so I gave it a very gentle tap to dislodge it. There again I didn't hit it very hard and it's definitely been banged around more than that in it's life. Just taking it home in the car would've subjected it to more vibration and it's survevid that. EDIT: It's a Gould Advance OS250B.
__________________ I do not answer private messages asking for help because no one else can: benefit from advice I may give or correct me if I'm wrong. Please ask on the open forum if you have a question and I'll be happy to help, if I know the answer. Last edited by Hero999; 28th October 2006 at 07:28 PM. | |
Hi Hero999, There's only a doubler circuit for the anode voltage, there should be approx. 2,8 kV on the anode of the crt. There will most likely be a negative voltage on the cathode, the four 4µF capacitors are all connected in series ! Without resistors to evenly divide the voltage between the capacitors. The total accelaration potential will be the sum of both.I think you might need a manual ? on1aag. | |
oops...well...time to shell out on that nice new Tek you have been hankering after for years... | |
| | #4 | |
I have been on Ebay looking, there are some deals for sure. Dual trace 100Mhz storage scopes with recent calibration date (1 year) for a couple hundred. But be careful, I almost convinced myself (birthday coming up) I need a DS2024 (I think it was). It went for $1700 but I went up way more than I wanted to spend (but it was so nice). I would do anything my wife told me for a couple days to own one (but I would want to see the list she had first).. Oh and I can not afford it | |
| | #6 | |
It will glow if there is a short but no further damage should be done and so you can trace the fault. As you wrote, a faulty cap or diode is the most likely cause. Len
__________________ Len | ||
| | #7 |
An old scope like that may not be worth a lot of investment of time or money, although I understand the attachment one develops for old, familiar, instruments. Is this an instrument you have some history with, or was it newly acquired? Checking the capacitors is a good start. If you lack a capacitor checker, remember that some DVMs come with a capacitor check function and they are often quite inexpensive. Alternatively, some crude tests are possible with just a DVM or VOM. Having several identical capacitors for comparison greatly facilitates such cheap and dirty tests. Set your DVM/VOM on a range that charges the capacitor over a perceptible period of time. Apply your tests leads to the capacitor and observe the dynamic response of the pointer. (It is much more difficult to to this test with a DVM because looking for a trend in a series of flashing numbers is difficult. Additionally, the current supplied by the DVM in the resistance mode may be so low that the capacitor does not charge up in a reasonable period of time.) At the instant you apply the leads to the capacitor, you should see the Ohmmeter pointer dip to nearly zero, then gradually climb back up to near infinity. If the voltage indication does not climb up to a very high resistance, the leakage is probably too high. If the pointer doesn't dip to near zero initially, the capacitor may be open. If the needle dips to a low value and stays there, the capacitor is probably shorted. You are lucky that you have several of each type of capacitor on the board. This allow you to observe the typical charging time of each capacitor of interest and compare the needle dip characterists of each. Better capacitor tests can be performed with higher voltages and more sophisticated equipment, but the tests described above can tell you most of what you want to know about your voltage multiplier capacitors. If you do use high voltages to test the capacitors, be very careful. Since you say that you heard a buzz just before the 'scope failed, you should test all rectifiers in the power multiplier circuit and other parts of the power supply. The test is most reliable if you disconnect one end of the diode from the board to avoid influence from nearby components. You should see a low resistance (<100 ohms) in the forward direction and a very high resistance (tens or hundreds of megohms) in the reverse direction. Here, again, testing at a few volts out of the ohmmeter is not as revealing as testing near diode reverse voltage rating, but it is readily available, cheap, and capable of revealing ordinary defects. Don't overlook simple, very close examination of the circuit board for signs of overheated components, bad solder joints, cracked conductors, etc. A magnifying glass is very helpful here. Be sure that the unblanking pulse is getting to the proper pin on the CRT. Check the CRT filament pins for continuity. If the tube filaments are shot, you are pretty much up the creek. Unless you stumbled across a replacement CRT at very low price, it will probably not be worth replacing the CRT, even if you can find one. Use a high voltage probe to confirm the presence of the proper high voltages on the CRT. You will not be able to measure the exact voltages due to loading by the measuring probe. However, you should be able to confirm the presence of a high voltage at the HV terminals. Check for the presence of appropriate voltages on the power transformer. Old 'scope power transformers are usually specials and not worth the cost of replacement. Have fun, and be careful. awright Last edited by awright; 29th October 2006 at 06:13 AM. | |
| | #8 | |
Thanks for your advice I'll try out your suggestions and get back to you with the results. Another annoying thing is the capacitors aren't fitted with bleeder resistors so they don't discharge when the supply is disconnected to discharging them manually will be a pain.
__________________ I do not answer private messages asking for help because no one else can: benefit from advice I may give or correct me if I'm wrong. Please ask on the open forum if you have a question and I'll be happy to help, if I know the answer. | ||
| | #9 |
"Another annoying thing is the capacitors aren't fitted with bleeder resistors so they don't discharge when the supply is disconnected to discharging them manually will be a pain." Well, at least that's very easy to fix. awright | |
| | #10 | |
Been there, done that!. | ||
| | #11 | |
| | #12 |
ain't it funny how yer arse puckers up within two secs after ya do ? | |
| | #13 |
It takes a lot less than 2 seconds for me | |
| | #14 | |
| | #15 | |
| dead, scope |
| HV scope probe question | Oznog | General Electronics Chat | 6 | 18th April 2009 04:56 AM |
| Crazy scope | spuffock | General Electronics Chat | 28 | 25th August 2007 06:29 PM |
| Digital and analog oscilloscope | patroclus | General Electronics Chat | 34 | 12th July 2006 03:34 AM |
| Dead Pixel Finder | Electric Rain | Electronic Projects Design/Ideas/Reviews | 8 | 10th October 2004 07:09 AM |
| Need help with blank Atmel AT90S2313, they all appear dead | bbiandov | Electronic Projects Design/Ideas/Reviews | 0 | 7th June 2003 10:24 PM |
