+ Reply to Thread
Page 1 of 2
1 2 Last
Results 1 to 15 of 17
Thread: lead acid rechargeable battery problem
  1. #1
    miaomiaooh Newbie
    Join Date
    Sep 2006
    Posts
    35
    Default lead acid rechargeable battery problem
    if use 8v ( because use voltage regulator 7808 drop down it) to charge a 6v lead acid rechargeable battery,will it spoil or explore the battery? ( because i dun have the battery's data sheet, so many thing i dun understand)
  2. #2
    penoy_balut Newbie
    Join Date
    Sep 2006
    Location
    Bagong Silang
    Posts
    171
    most battery labels indicate capacity and charging current if not available charge the battery on a current producing a little bubbling of its electrolyte
  3. #3
    HiTech Excellent HiTech Excellent HiTech Excellent HiTech Excellent HiTech Excellent HiTech Excellent HiTech Excellent HiTech Excellent HiTech Excellent
    Join Date
    Jun 2006
    Location
    Penna. USA
    Posts
    2,506
    You could use a variable DC power supply that has an ammeter to monitor charge current.... which you would then need to monitor and taper it off to a trickle amount. However if you can get ahold of an old discarded camcorder battery charger that has near the needed charge voltage, they often have the capability to trickle charge. Heating up a battery is bad and that's what you need to monitor as well.
  4. #4
    fingaz Newbie
    Join Date
    Aug 2006
    Location
    DERBYSHIRE, UK
    Posts
    265
    Charging a lead acid battery at higher than it's rated voltage will heat up the electrolyte (acid) and can make it evaporate quickly. It Will also (eventually) buckle the plates (which can cause a short circuit) because it's charging too quickly. as hitech suggested, ideally you need a variable power supply so you can reduce the charging current when the battery is nearly charged.
    Also remember then whilst charging, a lead acid battery gives off HYDROGEN gas, which is explosive so no sparks or smoking etc
    'Intellectuals solve problems. . . Geniuses prevent them.' . . . Albert Einstein
  5. #5
    bunghole Okay
    Join Date
    Jun 2006
    Posts
    104
    hello i is also trying to find a battery charger for a sealed lead acid battery, this data was on the side of it and it would help if anyone could help me;
    Application Charging Voltage Initial Current
    Floating Use 13.5~13.8V NO LIMIT
    Cycle Use 14.4~15.0v 2.1 a max
    ericgibbs Excellent ericgibbs Excellent ericgibbs Excellent ericgibbs Excellent ericgibbs Excellent ericgibbs Excellent ericgibbs Excellent ericgibbs Excellent ericgibbs Excellent ericgibbs Excellent ericgibbs Excellent
    Join Date
    Jan 2007
    Location
    Hampshire. England.
    Posts
    10,807
    Blog Entries
    13
    Thumbs up
    " Application Charging Voltage Initial Current
    Cycle Use 14.4~15.0v 2.1 a max "
    The charging info on the battery is to suit the way the battery
    will be used.
    Floating use: this is usualy where the battery is permanently
    connected to a charging source and the battery is only used to
    power external devices in the event of a mains failure.
    The battery charger is a 'constant voltage' type and its charge
    voltage MUST be set between 13.5 and 13.8 volts. Within these
    charge voltage limits, it can be permanently left on charge.
    Cycle use: this is usually where the battery is charged at its
    maximum rated voltage/current. The charger is again a
    'constant voltage' type, but with a 2.1amp current limiter.
    ONCE charged, the battery is disconnected and used to power
    external devices. And the cycle is repeated. ie; Charge then use.
    For bunghole, divide the above voltages by two for your 6 volt
    battery. ie; 6.7 thru 6.9 volts charge for floating use or 7.2v
    thru 7.5v for cyclic use with say a 2amp current limiter.
    If you use a +8 volt regulator connect two 3 amp diodes in series
    with the 8v connection to the +v terminal of the battery.
    If you have a +5v reg [7805] in your scrap box, make up a battery
    charger to give you a charge voltage of 6.9v. This is done by
    inserting a low value variable resistor in the 'gnd' pin
    of the 7805 and adjusting the resistor to give you 6.9v,at 1a max.
    If you want a diagram let me know.
    Regards
    EricG
  7. #7
    Join Date
    Jan 2007
    Location
    Hampshire. England.
    Posts
    10,807
    Blog Entries
    13
    Modified a drawing of a constant voltage charger for a sealed
    lead acid battery. Drawing shows components for 12v or 6v battery.
    The charger requires a dc input, at the voltages indicated, for
    6v or 12v operation, capable of supplying at least 1amp.
    The fuse on the battery output is recommended, if you short out
    a fully charged lead acid battery, without a fuse, you will
    get a flash and a dark brown smell.
    The diode D1 in series with the charger output, this is to
    prevent self discharge of the battery via the resistor divider,
    when the charger is not connected to a dc input source, also
    protects the regulator from high reverse voltages.
    It does slightly affect the stability of the constant voltage
    output.
    If you want to use the circuit for a bog standard bench supply,
    where the dc input source is always connected, omit the diode and
    the battery. This will give you a bench psu of +12v or 5v.
    [set P1 pot to suit] for your project experiments.
    Regards
    EricG
  8. #8
    RODALCO Newbie
    Join Date
    May 2006
    Location
    Akld, New Zealand
    Posts
    936
    If you charge a 6 Volts battery from a 7808, that voltage may be a little too high, and left on for long times the battery may boil dry and will produce excessive hydrogen gas which is explosive.
    Put a 1N4004, 1 Amp , or 1N5404, 3 Amp diode in series to reduce the charging voltage to 7.3Volts.
    Bear in mind that a 7808 is a 1 Amp regulator so if you run that from a 12 Volts DC supply, 4 Volts will be dissipated in there = 4 Watts, so it requires a reasonable sized heatsink. It will run very hot if not cooled properly and its thermal OL may kick in.
    Also a option you can do is put a 12 Volts 5 Watts lamp in series with your 7808, which will drop part of the charging voltage, you still have to check your battery for excessive gassing after 14 hours and do a voltage check with a DC multimeter.
    How big is your 6 volt battery ? (Ah)
    Please don't sent me private messages, I will not answer them.
    The questions asked can be discussed in the open forums.
    http://www.youtube.com/user/RODALCO2007 some interesting electrical stuff to watch.
  9. #9
    bunghole Okay
    Join Date
    Jun 2006
    Posts
    104
    Hello RODALCO
    Naprej zastava slave!
  10. #10
    bunghole Okay
    Join Date
    Jun 2006
    Posts
    104
    i don't have a 6v SLA i have a 12v 7.0ah one
  11. #11
    bunghole Okay
    Join Date
    Jun 2006
    Posts
    104
    EricG, i sees your diagram and some of it looks confusin. Some parts are labeled so they are the second of that part and also the capacitors. I think they are labeled in Mega-Farads, when 1 farad is = to one million uF. Could you clear that up maybe and see if you have a "cycle use" charger in stead of a constant voltage one. Thanks
  12. #12
    RODALCO Newbie
    Join Date
    May 2006
    Location
    Akld, New Zealand
    Posts
    936
    Bunghole Hi, i saw you post and that was a 12 Volts SLA, Eric explains that very well how to get about it.
    My reply was for the topic starter Miaohmiaooh who has a 6 Volts battery to charge from an 8 volts regulator.
    There was not much explanation what supply he had, or what he wanted to achieve.
    I assume that he had a 12 volt charger and connected a 7808 IC on the output to reduce the voltage to 8V to charge a 6V battery.
  13. #13
    Join Date
    Jan 2007
    Location
    Hampshire. England.
    Posts
    10,807
    Blog Entries
    13
    hi bunghole
    the caps are microfarads.
    Edit my drawing with the bits you cannot understanding, repost it and I
    will try to expand my explanation.
    Dont worry to much at this time about the amp-hour capacity of your
    battery. The charger will do the job, just a bit slower. You can always
    use a higher power regulator in the future.
    REMEMBER: do not exceed the max charge voltage or current of the battery.
    Regards
    EricG
  14. #14
    bunghole Okay
    Join Date
    Jun 2006
    Posts
    104
    EricG thanks for the about the caps and also like F2 for fuse #2 but there is no F1 and D2 for diode #2 when i isn't seeing D1
  15. #15
    bunghole Okay
    Join Date
    Jun 2006
    Posts
    104
    -Also this charger is for the floating use isn't it. What kind of power supply do i need for it and can i use this charger to charge the battery and leave it connected, but cut off the power supply and then still use the battery for applications and leave the charger connected?
    -Thanks?!?3
+ Reply to Thread
Page 1 of 2
1 2 Last
  1. rechargeable lead acid batteries
    By computer in forum General Electronics Chat
    Latest: 10th May 2004, 07:16 PM
  2. 12v Sealed lead acid battery charger
    By andi_n2004 in forum Electronic Projects Design/Ideas/Reviews
    Latest: 27th April 2004, 12:52 PM
  3. max current on rechargeable PP3 battery ?
    By defcon31 in forum General Electronics Chat
    Latest: 26th January 2004, 08:52 AM
  4. Extending car battery life - Is it possible ???
    By chouette in forum Electronic Projects Design/Ideas/Reviews
    Latest: 25th January 2004, 10:54 AM
  5. Stand by charging method for a Car battery
    By Sarac in forum Electronic Projects Design/Ideas/Reviews
    Latest: 8th May 2003, 12:43 PM
Tags for this Thread
