Old 25th October 2006, 08:08 PM   (permalink)
Default Photo Etch - - - UV Tubes
I had a go at photo etching today but the output was poor, probably due to the 2 tungsten bayonet fitting UV bulbs I was using and so I want to get a couple of UV tubes to replace them. I need tubes no longer than 300mm long or i'll have to make another box. I looked in Maplin and couldn't find anything suitable only security lights etc. I also looked on the RS website, they do T5 lights a pair for £16.95 (+VAT) with starters, and a ballast for £4.60 (+VAT) each. I would need the end caps also.
Does anyone have a supplier that they can recommend or should I go with RS ??
spondootre is offline
Old 25th October 2006, 09:07 PM   (permalink)
UV tungsten bulbs don't give much UV light, they mostly give visible violet which can make some fluroescent dyes glow. They are totally useless for exposing photoresist board.
If you want something from Craplin their 15W compact fluroescent bulb will work.
http://www.maplin.co.uk/Module.aspx?...3124&doy=25m10
I'd prefer RS, here's what you need.
Insect killer tube
8W ballast for one 8W tube.
OR:
I think you might be able to use a 16W ballast for two 8W tubes?
For more information check RS's guide.
Screen name: Aloone_Jonez
Hero999 is offline
Old 25th October 2006, 09:18 PM   (permalink)
They also do this one :
http://rswww.com/cgi-bin/bv/rswww/se...cape&Nr=avl:uk
Which is a direct replacement for their exposure tanks, they are T5 tubes also but more expensive, is their any difference? Also those tubes say they come with a starter, but I didn't think T5 Ballasts had a starter?!
Old 25th October 2006, 09:38 PM   (permalink)
Also the downfall to RS seems to be that I have to buy 10 ballasts!!
***EDIT***
Scratch that I found another that can be bought singularly
Dimming fluorecent light tubes raitl General Electronics Chat 14 14th March 2006 07:37 PM
photo detector circuit renaissances21 Electronic Projects Design/Ideas/Reviews 3 24th November 2005 12:13 PM
Photo fabrication for PCB's Johnson777717 General Electronics Chat 2 25th June 2004 05:48 AM
Testing tubes without a tube tester??? captainkirksdog General Electronics Chat 8 24th January 2004 11:05 PM
Photo Resistor Project Electric Rain Electronic Projects Design/Ideas/Reviews 1 24th July 2003 08:26 PM
