I now believe my post was unclear, so now i will try to clarify.
I have a battery, four motors, and a row of single pole swithes. I would like to flip one switch and have some of the motors run forwards, some backwards, and some stay off. If i ground all the negative leads back to the battery, i can not make them turn backwards. If i ground all the posotive leads, i can not make them run forwards. Is there a way without going to double pole switches? I do not want anything expensive or overly difficult for a newbie to wire. Thanks.
Old post:
I am making an ROV (model submarine) and i have a few wiring questions. I wanted to use a modified playstation controller and i am probably going to soder a board to make diffrent controls. To make it work properly, say when i press button 1, then motor 4 runs forward, 1 runs backwards, and 3 runs forward. I will also have many similar buttons. Since i am using dc motors, i know i have to just switch the polarity, but since i am trying to feed a + to one set and a - to another set, i am unsure of how to wire it up. If i ground the motor's - to the battery, that motor will not work properly in reverse. It seems that i need a switch that connects both a + and -, but that would mean i can not use my contoller. Also i dont want anything fancy or that costs a lot. Is there a way?
Please help.
