Old 19th October 2006, 10:00 PM   #1
Default PCB error
Hi There,
After etching a PCB I discovered a big spot across some of the traces - proberly from a finger. I transfered the PCB layout from a transperant film. What would be the best way to remove "finger" and others from both the PCB and the film before etching without destroyng them?
Electronics4you is offline
Old 20th October 2006, 09:26 AM   #2
Don't handle either the film, or the PCB, just touch the edges - cleanliness is vital!.
Old 20th October 2006, 11:50 AM   #3
or wear latex/nitrile gloves ... that way the missplaced thumb won't cause any grief.
as far as your pcb, that area is ruined, you could possible etch and then use a fine blade / very fine dremel bit to remove the offending bits of copper bridging the traces
the film is ruined, anything to clean the thumbprint off will also damange the plastic film or remove the toner/ink.
If you don't have a planet, what good are gold bars?
want to contact me directly? gmail gordonthree
check out my project website: http://projects.dimension-x.net
Favorite numbers:
09 F9 11 02 9D 74 E3 5B D8 41 56 C5 63 56 88 C0
justDIY is offline
Old 20th October 2006, 12:38 PM   #4
Post Hello, sort anoob here
hello ladies and gents!
I've been kind of lurking around.
I love this site! thanks for having me
Nanbe1st is offline
Old 20th October 2006, 09:29 PM   #5
I wouldn't recommend using film because it's far too sensitive to finger prints. Try using tracing paper, it diffuses the light very slightly so fine inperfections like specks of dust and finger prints while keeping the important stuff like your artwork.
if I know the answer.
Hero999 is offline
error, pcb
Need some help with a code provided by ATMEL ikalogic Micro Controllers 1 23rd January 2007 03:46 PM
Z8 Encore Error index out of range mootaccount Micro Controllers 2 17th October 2006 03:23 PM
MPLAB SIM ERROR gastonanthony Micro Controllers 7 28th April 2005 06:03 PM
Syntax Error with PBP and Mplab simple&cheap Micro Controllers 5 29th September 2004 02:48 AM
Ask for the principle of error amplifier in PWM swear_swear Electronic Projects Design/Ideas/Reviews 2 29th July 2003 02:07 AM
