Old 16th October 2006, 01:22 PM   #1
Default 12vDC -> 48vDC
Is it possible to go from 12vDC to 48vDC using one 12v SLA and 4 transformers? I was thinking I could run each transformer off from the battery, then wire the transformers in series, can it work that way? If not, is there another easy way to get a boosted DC voltage like that?
Life is what you make it.
joecool85 is offline
Old 16th October 2006, 01:24 PM   #2
No, you can't feed DC to a transformer, you need AC.
Old 16th October 2006, 02:59 PM   #3
There is no easy way to convert DC voltage up or down, especially at power-level currents. THat's why we use AC in power grids- so we can use transformers. You need a DC-DC switching converter- if it will boost more than half an amp or so, be prepared to pay a few hundred at least for a very large and heavy converter.
dknguyen is offline
Old 16th October 2006, 03:13 PM   #4
Ok, good stuff to know. Thanks for the info!
Old 16th October 2006, 07:16 PM   #5
What current do you require?
You can buy ICs that will do this if you add a couple of componants.
if I know the answer.
Hero999 is offline
>, 12vdc, 48vdc
Need Advice on 12vdc mustafa56 Electronic Projects Design/Ideas/Reviews 5 21st September 2005 08:15 PM
Need Help with a 48Vdc to 24Vdc regulator Loki7000 Electronic Projects Design/Ideas/Reviews 2 21st May 2005 01:59 AM
Microprocessor control of a 12Vdc motor ptewright Electronic Projects Design/Ideas/Reviews 7 4th May 2004 06:59 AM
dc Amplifier 12Vdc to 5Vdc dansoarr Electronic Projects Design/Ideas/Reviews 12 1st May 2004 11:23 PM
Need help on dropping voltage from 12vdc. to 4.5vdc? lt_1956 Electronic Projects Design/Ideas/Reviews 4 29th June 2003 05:07 AM
