Old 16th October 2006, 04:27 AM   (permalink)
Default Very simple voltage lowering 12v to 7.8v
Just like the topic says. It seems soo simple, i have 12v from a car (actually it changes from 12-14v) and i need a steady 7.8v. How should i do this. I need to finish this by tomarrow and im in a bind. I need the easiest way to do this. Its for a small screen in a car, the power jack runs on 120VAC and outputs 7.5VDC. So i need the strait 7.8v DC in the car..
EDIT::: Sorry, it should be 7.5V DC instead of 7.8
markland556 is offline   Reply With Quote
Old 16th October 2006, 04:37 AM   (permalink)
We can't help you if you don't say how much current. An LM317 can supply up to 1.5A but will need a heatsink at such a high current. Just 2 resistors set its output voltage.
Old 16th October 2006, 04:38 AM   (permalink)
How much current does your small screen draw?
Ron
Roff is online now   Reply With Quote
Old 16th October 2006, 04:43 AM   (permalink)
The power supply puts out 1500ma... but im not sure how to test how much the screen draws..
Old 16th October 2006, 10:48 AM   (permalink)
one thing to watch out for though is noise - if the equipment was designed to run off 50/60hz derived smoothed dc, then it may not like the noise that you usually see on the 12v supply of a car
Transformers are work
Electronics is a hobby
grim is offline   Reply With Quote
Old 16th October 2006, 01:15 PM   (permalink)
Leave your vehicle headlights on overnight. Tomorrow morning you'll have 7.5 volts at the cigarette lighter socket.
HiTech is offline   Reply With Quote
Old 16th October 2006, 01:57 PM   (permalink)
With the crude circuitry on the board i dont think it will be too much of an issue. Is it as easy as adding in a resistor to the power line?
Old 16th October 2006, 04:47 PM   (permalink)
Default 7V5 voltage regulator.
Hi Markland556,
You could use a simple 3 pin regulator like the L78S75CV, two small
capacitors and a (large) heatsink.
http://uk.farnell.com/jsp/search2/br...questid=769486
You could also add an extra 1,5 hm: ;5 watt resistor to connect the
circuit to the battery to take away some of the dissipation of the regulator.
on1aag.
on1aag is online now   Reply With Quote
Old 24th October 2006, 10:11 PM   (permalink)
hey, quick question. I got those regulators. Now im a little confused because the data sheet for it is kinda weird. But all i need to do is hook +12v into the input and the ground then the last with will have +7.5v??
Old 24th October 2006, 11:42 PM   (permalink)
my guess is that the screen actually runs on 5V and the 7.5 V requirement is to allow the regulator to do it's thing. Does the unit get hot when you run it from your wall wart? If not then I'd check the current (dmm set on current in series with the wall wart). If it's fairly low, you may actually be able to just use 12V. Even if it's too high, you should know the current to determine whether you will need a heatsink.
philba is offline   Reply With Quote
Old 24th October 2006, 11:51 PM   (permalink)
here's something I knocked up for ya to use...the pass transistor (3055) doesn't have to be a 3055, but anything with similar gain and current handling will do, just make sure it's insulated and on a good heatsink, because it will put out around 7W of heat...the zener diodes are pretty slack too, any combination that makes up 8.6 - 9v will do you...
I hope this helps ya out
Well...duh!! me
here's the corrected schematic...
tunedwolf is offline   Reply With Quote
Voltage ElectroMaster Electronic Theory 44 8th August 2007 05:35 PM
I am not getting ripple voltage at the output dar2525 General Electronics Chat 3 14th July 2005 02:20 PM
12vdc -> 7.5vdc transformer gulaz Electronic Projects Design/Ideas/Reviews 10 7th May 2004 07:59 PM
Accurate low voltage diff measurement Oznog General Electronics Chat 3 3rd May 2004 04:41 AM
lowering voltage and current.... ThE_sPaCeCoWbOy General Electronics Chat 18 4th December 2003 03:01 PM
