Old 15th October 2006, 07:24 PM   #16
Originally Posted by HarveyH42
Thanks, could have sworn NiCds were 1.2 volts.
I go to www.energizer.com for battery datasheets.
Battery cells have an internal resistance so their voltage drops as their load current is increased. At the low current for your LEDs then the average voltage is 1.3V or more per cell.
The cheap price you paid for your LEDs indicates a "copy-cat" manufacturer with poor reliability.
audioguru is online now
Old 15th October 2006, 09:01 PM   #17
Yeah, I've kept the copy-cat thing in mind. I got some of these same style LEDs from China, and replaced 6 in less than a month on the light bars I made for growlights, but they have been working for couple months now at 40 mA. Oh, there is no noticiable difference in the cactus under the LEDs and the ones about 5 feet away, both get the same daylight.
HarveyH42 is online now
Old 15th October 2006, 10:39 PM   #18
Compared to daylight, the tiny amount of light from LEDs is nothing.
Old 16th October 2006, 12:08 AM   #19
Yes, but it's about 6 hours more light after the sun sets, and on cloudy days (not many this year).
Old 16th October 2006, 12:18 AM   #20
Oh, important saftey tip: Don't test these supe-flux LEDs with an old (thought it was the mostly dead one anyway...) 9 volt battery, they actually explode. The lens hit the ceiling (5 - 6 feet). The battery turned out to be fairly good, 8.73 volts. The old one was hiding under a schematic.
I usually pop the tops of and use them for battery clips, cheap bastard that I am... Actually, I solder them to PCBs, easier than tearing apart one with leads. Guess that makes me more lazy, than cheap.
Old 16th October 2006, 12:32 AM   #21
You test LEDs without using a current-limiting resistor?
Do you also jump out of airplanes without using a parachute?
Old 16th October 2006, 06:39 AM   #22
It was only for a very brief second to make sure of which set of leads was anode and cathode. I didn't expect it to actually explode on contact, figured it wouldn't even get warm.
Anyway, the experiment was a miseriable disapointment, the two LEDs were very dim. Will make some measurements after work and see why.
Old 16th October 2006, 10:03 AM   #23
Yes, also a good method to test a fuse to make sure it works.
Speaking of which I must add that LEDs I own from various manufacturers do not follow a standard on the polarity indication.
Long/short leads or a flat on the LED body will not always indicate the correct polarity.
Or would I say most do but a few don't.
L.Chung
eblc1388 is offline
Old 16th October 2006, 04:41 PM   #24
Over-current can blow-up an LED much faster than a split second. The chip is very small and will reach melting temperature long before its case begins to get warm. Their reverse voltage rating is only 5V so it might also blow-up when its supply is reversed.
I have installed and tested hundreds of LEDs and never blew one up.
Old 16th October 2006, 05:57 PM   #25
I wouldn't have done it with a good 9 volt battery, the spent one should have be okay, or at least not enough to send pieces flying. Could have lost an eye from that explosion. Got lucky, figured I'd share my stupidity and hopefully spare someone the grief.
Old 16th October 2006, 06:47 PM   #26
A good way of testing LEDs is to connect the cathode to -V, moisten your finger and use it to bridge the gap between the LED and +V of the battery. The current drawn is too small to hurt you or the LED which should glow quite dimly but you should be able to see it.
if I know the answer.
Hero999 is offline
Old 16th October 2006, 07:08 PM   #27
You can't find an ordinary resistor?
Old 16th October 2006, 07:56 PM   #28
Yes but I normally don't bother searching for one.
Hero999 is offline
Old 17th October 2006, 06:35 AM   #29
Okay, finally succesful run. I made some measurements, got weird ass numbers, so figured I did something wrong. Did some more research...
Instead of driving the LEDs from the output pin of the LM317, I need to come off the Adjust pin (wrong side of the resistor). Also learned that I needed 3 volts above what the LEDS needed, so for the 5.4v volts from the NiCds, only had enough for 1 LED. Left it running at 7:30pm, it's still bright at 1:30 AM.
One odd note, measured 64.8 mA with the meter between the LED and neg. battery. The resistor is 10 ohms.
Old 17th October 2006, 09:00 AM   #30
Nothing odd. This measuring method is only good if your LM317 input voltage is higher than 5.4V, perhaps 7V or more because you have introduced extra resistance(the DVM) into the circuit and might have exceeded the regulating range of LM317 to maintain its output. Proper method is to measure the voltage across the 10 ohm resistor and calculate the current.
If your constant current circuit is working, you should get a constant 1.25V across the 10 ohm resistor, which also means a constant 125mA current. Anything less indicates that the LM317 input voltage is too low for regulation.
L.Chung
eblc1388 is offline
constant, current, lm317, questions
Resistors Marks256 General Electronics Chat 57 16th May 2009 11:22 PM
constant voltage, constant current Lead Acid Battery Charger Erwin_Macaraig Micro Controllers 1 4th October 2008 01:26 AM
Current Limiting Questions pop General Electronics Chat 4 15th September 2006 02:35 PM
Req: simple low drop constant current source Dominique General Electronics Chat 10 9th February 2006 03:20 PM
Will current Mirror circuit deliver constant current to LED? Haru General Electronics Chat 10 14th April 2005 11:07 AM
