I need to make some thing to control a directional motor. its a simple motor reverse curent of wires it reverses direction. i can't think of any way to do it with out using four switches. what i need is to be able to do is have +/- on on switch + Batt _ +/- motor +/- thank you for helping me.. | |
Does it have to be 4 switches? I know how to do it with a single DPDT switch.
will it still go in both directions
Yes it will!.
what do i use
| | #6 |
oh its a 12v motor
| | #7 |
The attached should help. The switch has 6 terminal, pretty common.
| | #8 |
whats the m stand for
| | #9 |
I imagine 'motor' - how many other m's were we discussing?.
| | #10 |
Okay... First, should you be messing around with electronics? You asked about a (M)otor... Will give you a quick safety tip when using a soldering pencil, don't touch the metal end while its plugged in, very hot, hurts bad. The M is for the connection to your motor. Two wires, two connections. | |
| | #11 |
half a sleep here can i get one of these at like radio shack
| | #12 |
Don't know about Radio Shaft, probably. I haven't been in one since I was in my 20s... They are very common switches, might already have one or two laying around. I attached a photo of two I dug up, but there are other styles, like push button, slide switch, rotory, even relays come in this configuration. They can even come momentary (have to hold it), and a center OFF position.
| | #13 |
Just a quick note. What may not be obvious from the above comments, if the DPDT switch is just two position, you will need another switch to stop the motor. If the DPDT switch has the centre off position, you will just need one switch. If the motor you are trying to switch is more than just a little toy, i would recommend stopping the motor before changing directions. Just slamming the thing into reverse while running forward can lead to some big currents flowing. And as we know, big currents can release the smoke which is inside all electrical and electronic devices! JimB
| | #14 |
Isn't smoke and sparks the best part of learning about electronics? In high school we destroyed all kinds of stuff, just to see what happened when you abused stuff. The instructor didn't seem to mind if they were salvaged parts, and didn't actually see us doing it.
| | #15 |
well as someone has witten in his sig all electronic components run on smoke let it out and it won't work anymore
__________________ I AM the exeption that disproves the rule in many ways but the rules still apply (unfortunately) www.simonsphotography.org.uk/ - My other hobby www.rushdenrotaract.org.uk/ - make a difference and have fun ! Never buy "Trust" products, all mine broke !!! | |
| motor |
| Project: DC Motor Control (using a single switch) | arijit18 | Electronic Projects | 19 | 21st October 2009 08:33 PM |
| Please help me to build a bipolar stepper motor control | thusithk | General Electronics Chat | 7 | 5th March 2008 03:36 PM |
| Motor Position Control Problem | YAN-1 | Electronic Projects Design/Ideas/Reviews | 10 | 31st March 2006 03:03 PM |
| Stepper Motor Driving Using PIC16F74 | t_anjan | Electronic Projects Design/Ideas/Reviews | 0 | 31st January 2006 07:14 PM |
| RF Receiver and DC motor running from same power source? | adamthole | Electronic Projects Design/Ideas/Reviews | 15 | 18th May 2005 09:37 AM |
