Old 13th October 2006, 08:44 AM   #1
Default PCB color
Hi There,
Does anyone know how to make coloured PCB's?
Electronics4you is offline
Old 13th October 2006, 09:15 AM   #2
Lightbulb
Originally Posted by Electronics4you
Hi There,
Use a electrodeposited paint (a bit expensive). Plate the traces with silver, Ni or whatever and electrodeposit on top a metal or inorganic compound wich is coloured or can be transformed in something coloured (like oxidising a metal). Use coper sulphate (and cover it with some transp polish), iron and oxidise it (can get black or redish-orange), Ni and chemicaly modify it to get a bluish colour and so on.
If you're a masochist paint the traces manualy :lol
Use a photo or phototermal deposited ink or dye.
Those ideeas came in to my mind. I'd realy like other sugestions.
If is too complicated.....most of the times is the wrong way.
Tarsil is offline
Old 13th October 2006, 03:07 PM   #3
The color on manufactured PCBs come from the solder mask. It is basically an epoxy type compound which is silkscreened onto the boards at the time of manufacture. Usually it's green, but I've also seen black, blue and red.
JB
jbeng is offline
Old 13th October 2006, 03:35 PM   #4
Is that how they make the solder resist layer?
if I know the answer.
Hero999 is offline
Old 13th October 2006, 03:49 PM   #5
Yes, it's silkscreened on the board.
Old 16th October 2006, 06:52 PM   #6
Question
Can u give details about the epoxy compound? It's feasable to be used in noindustrial conditions?
Tarsil is offline
Old 16th October 2006, 09:48 PM   #7
I've never seen a hobbyist do a silkscreen. presumably, since it's possible to make t-shirts at home by silkscreening, then one would assume it's also feasible to do so for your PCB's, but the extra effort required to make the silkscreen mask for every board you lay out is not worth the effort in many cases... if you reach the point where you really need a silkscreen, then you probably ought to be getting your boards made professionally anyway.
with that said, I've heard of people "silkscreening" their board by simply spraying the whole board with translucent green paint, such as that used on toy model kits (ie - Testors brand); apparently if you use the right kind of paint, it burns off under the heat of the soldering iron, so you can solder the board after and only the areas soldered will be exposed, the rest will remain painted. I've never gotten around to trying it, and I'd expect that the burned-off paint could make for some dirty solder joints if you weren't careful, but it sounds possible.
EEgeek.net
evandude is offline
Old 16th October 2006, 10:18 PM   #8
i've heard of that method too ... I think the paint recommended was Testors Acrylic Enamel Hobby Paint in a rattle can ... I stick to "silkscreening" after assembly ... little alcohol and wire brush action to clean things up and then spray it down with rustoleum black
If you don't have a planet, what good are gold bars?
want to contact me directly? gmail gordonthree
check out my project website: http://projects.dimension-x.net
Favorite numbers:
09 F9 11 02 9D 74 E3 5B D8 41 56 C5 63 56 88 C0
justDIY is offline
color, pcb
color detector shreik Electronic Projects Design/Ideas/Reviews 6 21st January 2005 02:04 PM
color Leappad screen? Oznog General Electronics Chat 0 10th July 2004 08:17 AM
Inductor Color code Johnson777717 General Electronics Chat 4 25th March 2004 12:05 PM
strange color camera problem schrodingerscat Electronic Projects Design/Ideas/Reviews 5 4th October 2003 08:25 PM
Digital Clock Color Change JaTaN General Electronics Chat 1 25th August 2003 02:31 AM
