tv repair
12 Last »
  1. #1
    johnny69 johnny69 is offline
    tv repair
    i need some help, i have a sony trinitron 32 inch television and it's one of the older models and i was given it cause they were upgrading and i've had it for 6 months now probably and it's been working perfectly up till a couple days ago and then the color started going on the screen now theres patches on it where the color is messed up, like someones holding a magnet up to it, it's still watchable but i was just wondering if there is anthing i can do to fix the color, i know it has nothing to do with the dials to adjust color, i assume it has something to do with the tube, i was just wondering if anyone could help me with the problem.
    thanks
  2. #2
    penoy_balut penoy_balut is offline
    check your degaussing coil circuit, you should hear a "thwang" sound when the set is turned on
    0
  3. Thread Starter #3
    got a twang
    when i turn it on i hear what could be considered a twang and then static on the screen as it turns on s oi assume thats what you mean
    0
  4. #4
    tunedwolf tunedwolf is offline
    I would say the degaussing circuit is up the kyber...
    Replace the positor, the little three legged box prior to the mains bridge, the coil that goes round the tube is attached to it if you follow the circuit. Make sure the set is unplugged from the mains before doing anything, and be very careful of charged capacitors. It might be prudent to stick a 100K resistor, with insulated leads, across the main ones in the power supply for a few secs each before you do anything else, just to be sure they are discharged. A nasty crack from the main smoothing block can easily kill a smps or worse, not to mention give you a new hairdoo.
    0
  5. #5
    avoid external magnetization, it can cause those color patches. you need a degaussing coil used by technicians to remove color patches, its stronger than the one in your tv
    0
  6. #6
    Nigel Goodwin Nigel Goodwin is online now
    Super Moderator
    A VERY common problem on those Sony's is the scan coils sliding back on the CRT neck, often with the rubber wedges falling out as well - however I sugest you don't try and do it yourself as it's a fairly 'scary' procedure with plenty of places to get shocks from!.
    0
  7. #7
    HiTech HiTech is offline
    First, try using an external degaussing coil moved randomly across the CRT's face while you slowly pull it away several inches, finished by turning the coil perpindicular to the CRT. If the color blotches remain then I would suspect what Nigel mentioned. Often if the rubber wedges fall out or slip out of position you can return them to their exact spot by carefully examining the back of the CRT surface for a slight outline of where they were. Sparingly apply some quality contact glue to hold them in place.
    0
    I will not explain electronic theory. For those who know, no explanation is necessary. For those who do not, no explanation is possible!
  8. #8
    audioguru audioguru is offline
    Quote Originally Posted by Nigel Goodwin
    On my Sony 32" TV, the bottom 2 rubber wedges fell out and the other 2 are very loose. They seem to keep the scan coils from sliding too close to the CRT. What keeps the coils from sliding away from the CRT?
    I didn't push very hard but the coils seem to be very secure.
    0
  9. #9
    ooooh...lovely...a real live sony scan yoke in yer hands...
    the static alone will frighten you as ya go near it...
    The last one I done was about 6-7 years ago, and the damned anode cap fell out in the middle of the procedure...started jumping about arcing here and there etc....was frighteningly funny to watch according to my collegues...
    The set survived, but I needed my purity adjusted afterwards...
    I do agree though, loads of the sony's I have worked on suffered from purity problems due to the scan yoke moving about, it just didn't sound like it was this from what johnny69 posted.
    Of course nobody mentioned that if he does play with the scan yoke, without a pattern generator, the tube set-up is unlikely ever to be close again. And in the case of a trinitron, a handful of those daft permalloy magnets won't go amiss either
    0
  10. #10
    Quote Originally Posted by tunedwolf
    Magnets?
    My Trinitron has 2 self-adhesive 1cm square things (magnets?) stuck on the back of the CRT and 3 stuck on the holder for the scan coils. The holder for the scan coils has a very strong looking clamp that holds it secure.
    0
12 Last »
Repair LI-ION battery pack (Gallopwire) 2PAC Mafia General Electronics Chat 9 24th November 2005, 06:32 AM
Oscilliscope repair jrz126 General Electronics Chat 12 18th September 2005, 06:34 PM
Is TV repair a dead trade? ThermalRunaway General Electronics Chat 16 17th April 2005, 08:28 AM
Trying to repair a PCB 2PAC Mafia General Electronics Chat 3 26th January 2005, 01:46 PM
repair membrane cable? GEN2TS General Electronics Chat 4 17th January 2005, 02:17 PM
Page Time: 0.09198 seconds      Memory: 7,660 KB      Queries: 16      Templates: 0
