as the title suggests, is the output of a 555 bipolar timer great enough to drive an irf740 n power mosfet. the application is for a coil gun do I need to addd an additional gate drive circuit? | |
The IRF740 and most other Mosfets are spec'd to turn on fully with 10V on the gate. A 555 will give an output of 10V when its supply is 11.3V. Use a 12V supply and it will be fine. An IRF740 is rated for a very high 400V but fairly low current. Is it useful to drive a coil?
About the curent.....no problem. About the voltage ...the treshold is like 4V max but at 10V RDS(on) is quite small so if u use like 12V for powering the 555...it's the best sol.
__________________ If is too complicated.....most of the times is the wrong way. | |
pulse rated current is 40A
watch out for the output sourcing capability of the 555 timer w.r.t. how fast you want to switch the FET
| | #6 | |
An ordinary IRF540 has a max on-resistance 10 times lower. You can't buy exactly what you need, so plan on the worst case then all your circuits will work.
| | #7 |
however the voltage rating is 1/3rd of the irf740, this would bring the energy stored in the cap bank from 450j to 50j
| | #8 |
Does this powerful "coil gun" launch small cars?
| | #9 |
no, but small bits of steel at high speed
| 555, bipolar, drive, large, mosfet, output |
| Function Generator output driver | evandude | General Electronics Chat | 6 | 31st January 2005 08:49 PM |
| Effects | stephenpic | Micro Controllers | 6 | 19th January 2004 12:57 PM |
| VERY low voltage on output pins, please help! | New2PIC | Micro Controllers | 1 | 18th January 2004 04:22 AM |
| How do I generate a potentiometer output? | klick | General Electronics Chat | 3 | 23rd November 2003 03:26 PM |
| Power Mosfet drive techniques | Optikon | General Electronics Chat | 8 | 21st November 2003 12:50 AM |
