Old 6th October 2006, 01:09 PM   #1
Default overhead projectors
Q) how to use a lamp to test a cct which has blown a fuse.
I dont really understand this question. can anyone help me.
elecguy is offline
Old 6th October 2006, 02:20 PM   #2
I don't really understand this thread!! Please explain your question in better detail. First off, by "overhead projector" do you mean the transparency projector type whereby a sheet of clear acetate is used on a glass platten/Fresnel lense? Or are you referring to a data/video projector that uses LDC or DLP technology? I gather that you are trying to substitute a lamp for a blown fuse? If so, typically a 60w incandescent lamp is temporarily wired in place of the fuse.
HiTech is offline
Old 6th October 2006, 06:17 PM   #3
A fuse blows due to over-current. If you bypass the blown fuse with a light bulb but the over-current problem isn't fixed then it might cause more damage.
audioguru is offline
Old 7th October 2006, 07:53 AM   #4
I think he means that when the fuse had blown to fit a new fuse of the same amperage and put a lamp in series with the supply.
This is actually a good idea because if the fault is still there the lamp will absorb most of the the surge and the damage to the cct board may remain minimal.
Start with a 60 Watt lamp first.
May have to use a higher wattage depending upon the load from the cct under test.
If it lights up to full brightness there is a dead short in the load behind it.
Please don't sent me private messages, I will not answer them.
The questions asked can be discussed in the open forums.
http://www.youtube.com/user/RODALCO2007 some interesting electrical stuff to watch.
RODALCO is offline
overhead, projectors
