Old 6th October 2006, 12:04 PM   #1
Default wrong DMM Led diagnostic...
Hey
VCR philips problem
When I checked the LED with DMM it shows me that the LED is good.
When I replace the old LED by the new one the VCR stated to work properly.
How can it me, the DMM shows that led is good while it is bad???
Zener_Diode is offline
Old 6th October 2006, 12:11 PM   #2
Originally Posted by Zener_Diode
Hey
VCR philips problem
All the DMM checks is if it's O/C or not - it doesn't mean it actually works!.
Old 6th October 2006, 12:18 PM   #3
What is O/C?
How can I check the components and to know that it works for sure?
Old 6th October 2006, 12:45 PM   #4
What is O/C?
'Open Circuit'
You place it in a circuit and confirm it works correctly, that's the only 100% way.
Old 6th October 2006, 12:50 PM   #5
Post
Hey
VCR philips problem
REading the other post too I'd say that LED doesn't have enought voltage to operate. 1.5V...I haven't seen a LED that can be operated from a single aa batery. So the LED is OK but it doesn't give any light. U should consider replacing the resistor before the led. What value does it has now?
If is too complicated.....most of the times is the wrong way.
Tarsil is offline
Old 6th October 2006, 02:04 PM   #6
It is an infrared LED I can't see it's light.
If I connect it to 10V through 10K resester I have 893uA current, 1V fells on diode.
if I rise the supply voltage the current rise too but the led voltage don't changed.
how can I know that he is good ot bad???
I don't remember exactly but I think there was a 76 om resester. 5V before resester and 1.5V on the led. When I put other LED everything started to work properly...
How can u explane this?
Old 6th October 2006, 02:14 PM   #7
Unfortunately, some components may test good under static type testing. However in the dynamic situation (under use/load) the component may act up or not work at all. This is not uncommon.
HiTech is offline
Old 6th October 2006, 03:48 PM   #8
If you have a digital camera with a preview screen, you can see it light up that way...
HarveyH42 is offline
Old 6th October 2006, 09:29 PM   #9
Post
76 Ohms!?
How about puting the LED in series with a 5V PS (could be voltage taken from the VCR), a 150 ohm res and a ampmeter. See the curent drawn by the led.
Also see http://www.gizmology.net/LEDs.htm.
Tarsil is offline
diagnostic, dmm, led, wrong
Am i wrong here Megamox General Electronics Chat 18 23rd December 2005 11:55 PM
Onboard diagnostic system help needed RK NAIR Electronic Projects Design/Ideas/Reviews 11 18th November 2004 05:28 PM
I must be doing something horribly wrong, SAVE ME!!! Glyph General Electronics Chat 0 4th October 2004 03:01 AM
Whats wrong with my code ??? pike Micro Controllers 10 23rd December 2003 12:58 AM
Hmm what's wrong? daviddoria General Electronics Chat 10 27th March 2003 08:25 PM
