Hi, I have been doing a project from quite some time now but have hit a interference problem, the project consists of GSM+GPS+MCU usual tracker thing. I placed one large ground plane on both sides using a polygon pour after routing but I think this has caused a problem whereby I get interference on the 3.3v from the 3.8v supply to the GSM (in metal can), all IC's have decoupling caps and the GSM has smoothing as per manufacturers spec. My question is, what it the best general rule for ground planes in a mixed deign like mine? 1) One ground place on both sides with more smoothing 2) two/three ground planes, power circuit, GSM, MCU 3) Run a track around outer edge on both sides Hope someone can help, I know it's a large subject but just some guidance as to the best approach. Thx | |
I'm not sure if this is going to be terribly helpful for this particular problem, but in the vein of "here's the 'FM', read it when you get a chance": http://www.sigcon.com/pubsIndex.htm All you wanted to know about signal integrity issues. How many layers is this board? | |
I've used many ground planes, and power planes for that matter. Generally, I embed them in the internals of a multi-layer design so they're not visible from either side. The problem is, that ground planes are basically large capacitive plates, and can hinder high frequency circuits, so you have to be careful, as they may introduce unwanted parasitics. I use them in primarily mixed signal analog and digital designs. I usually have a ground plane in sensitive amplifying and signal conditioning circuitry. I usually split the ground plane into a digital and analog ground, keeping digital and analog circuits separate on the board. The A/D is usually where they meet. HTH.
__________________ "Everything that is done in the world is done by hope." -Martin Luther "There are two ways to live your life. One is as though nothing is a miracle. The other is as though everything is a miracle."-Albert Einstein | |
not only that but if you make the GND and power planes oo big they are a real pain to solder things downto, unless thermal relief vias a used
| ground, planes |
| What is Chassis Ground, Technical Ground, Circuit Ground? | victor | General Electronics Chat | 8 | 11th October 2008 12:42 PM |
| Mains ground point and circuit ground point | Johnson777717 | General Electronics Chat | 9 | 1st September 2007 11:19 AM |
| Isolated DC-DC Converter Ground Plane | dknguyen | General Electronics Chat | 18 | 6th August 2006 10:03 PM |
| PCI bus | hodamoodi | Electronic Projects Design/Ideas/Reviews | 22 | 17th June 2006 09:42 AM |
| Do I need seperate ground planes for this circuit? | Echelon 01 | Electronic Projects Design/Ideas/Reviews | 3 | 29th October 2003 08:09 AM |
