I don't get something about this diagram. The conductors are supposed to be coils, but they just look like wires going in or out of the page to me. I can't physically imagine where the coil is and how it goes round and round. Like how does the coil go to attach one pole to the other? Like is the conductor going out of the page and jumping back into the page to make the coil? Because if it is, it still seems just like a single loop of wire rather than a coil. http://www.ece.ualberta.ca/~knight/e.../f_ac_gen.html Last edited by dknguyen; 6th October 2006 at 05:31 AM. | |
| | #2 | |
Each coil has a 'start' and 'finish'. In the star configuration, all 3 'starts' are connected together at a common point, and 3 phase power is taken from the 3 'finish' leads. In the delta configuration, the coils are connected start-finish, start-finish, start-finish. The 3 phase power is taken from these 3 connections. Both configurations produce the same amount of power, but the star provides less current and more voltage and vice-versa for the delta. Hope this helps | ||
| | #3 | |
He is starting with just a 1 turn coil, and when you read on he puts in multi-turns later in his maths. JimB
__________________ Experience is directly proportional to the value of the equipment ruined. | ||
| | #4 | |
http://www.ece.ualberta.ca/~knight/e..._rotation.html I can see where you are coming from but when you deal with a 3D object BUT you need to represent it in the 2D plane what can you do? the main piece of infomation is where the teeth are on the stator so they get represented. The only bit of infomation that is required (from a coil P.O.V.) is where the coil goes in and where it comes out (then imagine the end-winding linking the two abt in inch abt the paper) the dot & cross notation will show you the route, how many turns... does it really matter from this picture? no, the more turns just increases the Amp-turns that is produced but they still follow the same route, you could have one single turn with 1million amps or 1million turns with a single amp to get the same effect, so make the drawing simpler and show it as one turn later on when you start getting into specific infomation (and when you start getting detacted from the physical and more mathematic) then the # of turns becomes important | ||
Heh, turns out that a 4-pole system is easier for me to get because of the more obvious way that the coils are made physically. Thanks all.
| 3phase, diagrams, machine |
| Variable capacitor circuits | walters | General Electronics Chat | 92 | 7th February 2009 08:08 PM |
| Phase difference detector, 433.92MHz | AndyPLL | General Electronics Chat | 25 | 29th November 2008 07:19 AM |
| Measuring Phase | walters | General Electronics Chat | 25 | 3rd December 2005 09:24 AM |
| Electrical Phases Basics... | Rizorama | General Electronics Chat | 7 | 15th February 2005 03:55 AM |
| UK - 3 PHASE ELECTRICAL SUPPLY | Asjad | General Electronics Chat | 3 | 7th November 2004 08:49 PM |
