Old 5th October 2006, 08:12 PM   #1
Question desk counter
hi, i want to build a counter that is desk mounted. it needs to be able to count to 999 from single inputs by hand(finger) it also needs to be re-setable, and have a memory for several days at atime. a lcd readout would be nice! i know a small amount about what is involved, but amat a lost with which chips, etc.to use. please help!:
thanks for the info, but i'm a bus driver and don't have access to any programing things, nor do i know where to buy the bits required
nicvigni is offline
Old 5th October 2006, 08:39 PM   #2
Use a PIC and an LCD text module! - with a little code writing it will meet all your requirements with hardly any components at all!.
Old 5th October 2006, 11:31 PM   #3
Expanding on Nigel's suggestion, a PIC 16F84 or similar (newer for better power performance) chip, with an LMxxx LCD character display, a couple of push button switches and a five volt power supply may be your cheapest solution. If you plan on using batteries, I'd use 4 cells and drop the voltage back to 5v still with a regulator (LDO type) or even better use a boost converter to produce 5v from anything down to about 2v input supply. The LCD's can get a little temperamental at lower voltages than about 4.5V.
Also, take care with your software if you want several days performance from batteries - use the power saving facilities of the PIC chip such as sleep mode etc. and even blank the LCD if the buttons aren't pressed for a while - you then have potential for something that could work for weeks!
Madhouse is offline
counter, desk
Input Counter Pic16F84A (Code problems) loco Micro Controllers 4 26th September 2006 02:19 PM
Binary Counter. lord loh. General Electronics Chat 5 24th September 2005 07:52 PM
[help] Power consumption issue on bullet counter project * Lanzer Electronic Projects Design/Ideas/Reviews 13 26th August 2005 07:06 AM
How to stop the Counter mode is Timer 1 in the PIC16F877 avinsinanan Micro Controllers 1 11th April 2005 08:13 PM
Crude assembly counter Mark Lazarides Micro Controllers 5 28th February 2004 08:22 PM
